I managed to set up z2m and adding lamps was fairly simple, until I started adding the lamps from my garden.
These are Innr RS 227 T control via MQTT | Zigbee2MQTT
It took some patience to discover them in z2m and when they were finally discovered, the ‘brand name’/‘vendor’ stated ‘not supported’
I was stuck in that place and thought removing them and relinking them would be a good idea. The lamps couldn’t be removed on my first attempt so I tried again with force remove.
After this step, I haven’t managed to access z2m anymore. I have so far:
- Done reboots of all sorts
- Uninstalled z2m
- Removed all backup config found with file editor
and Attempted to reflash the zigbee dongle (which failed with the flasher and sort of succeeded except for one error with the .py script)
Really out of options now, I also can’t pin point whether this is because of a leftover setup in HA or related to the Dongle’s firmware
