I updated the conbee 3 stick on windows.
After bringing it back online in HA & Zigbee2MQTT I have some troubles with disconnected devices and entities without any reactions…
My card looks also really weird - but I dont know if this is “normal” and was before the update the same:
the log file (is this correct):
2025-01-22 07:34:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:34:21.268Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":228}'
info 2025-01-22 07:34:31z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:34:31.836Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":235}'
info 2025-01-22 07:34:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:34:31.996Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":235}'
info 2025-01-22 07:34:44z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Temp Filament', payload '{"battery":80,"humidity":22.1,"last_seen":"2025-01-22T06:34:44.837Z","linkquality":197,"temperature":16.7}'
info 2025-01-22 07:34:55z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:34:55.325Z","linkquality":201,"power":0,"power_outage_memory":"on","state":"ON","voltage":227}'
info 2025-01-22 07:35:15z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.03,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:35:15.631Z","linkquality":196,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":235}'
info 2025-01-22 07:35:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:35:21.426Z","linkquality":199,"power":0,"power_outage_memory":"off","state":"OFF","voltage":228}'
info 2025-01-22 07:35:23z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Blumensensor1', payload '{"battery":27,"battery_state":"medium","last_seen":"2025-01-22T06:35:23.044Z","linkquality":198,"soil_moisture":24,"temperature":20.3,"temperature_unit":"celsius"}'
info 2025-01-22 07:35:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:35:32.122Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:35:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:35:32.251Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:35:40z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:35:40.401Z","linkquality":197,"power":0,"power_outage_memory":"on","state":"ON","voltage":227}'
info 2025-01-22 07:35:55z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:35:55.469Z","linkquality":196,"power":0,"power_outage_memory":"on","state":"ON","voltage":227}'
info 2025-01-22 07:36:10z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.03,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:36:09.992Z","linkquality":195,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":235}'
info 2025-01-22 07:36:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:36:21.552Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","voltage":228}'
info 2025-01-22 07:36:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:36:32.344Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:36:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:36:32.441Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:36:53z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:36:53.113Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:36:55z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:36:55.692Z","linkquality":198,"power":0,"power_outage_memory":"on","state":"ON","voltage":228}'
info 2025-01-22 07:36:57z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.03,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:36:57.309Z","linkquality":196,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":235}'
info 2025-01-22 07:37:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:37:21.727Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:37:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:37:21.919Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:37:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:37:22.047Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:37:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:37:32.568Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:37:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:37:32.696Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:37:55z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:37:55.866Z","linkquality":201,"power":0,"power_outage_memory":"on","state":"ON","voltage":228}'
info 2025-01-22 07:38:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:38:21.918Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:38:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:38:32.823Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:38:32z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:38:32.935Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:38:37z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:38:37.610Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":235}'
info 2025-01-22 07:38:56z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:38:56.041Z","linkquality":201,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:39:08z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:39:08.132Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:39:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:39:22.093Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","voltage":228}'
info 2025-01-22 07:39:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:39:33.029Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:39:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:39:33.143Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:39:43z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Temp Filament', payload '{"battery":80,"humidity":22.1,"last_seen":"2025-01-22T06:39:43.614Z","linkquality":197,"temperature":16.7}'
info 2025-01-22 07:39:56z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:39:56.216Z","linkquality":197,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:39:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:39:58.602Z","linkquality":195,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:40:03z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:40:03.743Z","linkquality":196,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:40:07z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:40:07.504Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:40:15z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:40:15.639Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":235}'
info 2025-01-22 07:40:20z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:40:20.668Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":234}'
info 2025-01-22 07:40:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:40:22.220Z","linkquality":195,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:40:28z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Xbox', payload '{"last_seen":"2025-01-22T06:40:28.305Z","linkquality":177,"state":"OFF","update":{"installed_version":16909577,"latest_version":16909577,"state":"idle"},"update_available":false}'
info 2025-01-22 07:40:29z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Xbox', payload '{"last_seen":"2025-01-22T06:40:29.345Z","linkquality":189,"state":"OFF","update":{"installed_version":16909577,"latest_version":16909577,"state":"idle"},"update_available":false}'
info 2025-01-22 07:40:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:40:33.252Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:40:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:40:33.364Z","linkquality":193,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:40:40z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:40:40.041Z","linkquality":193,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:40:40z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:40:40.233Z","linkquality":199,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:41:07z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Blumensensor4', payload '{"battery":12,"battery_state":"low","last_seen":"2025-01-22T06:41:07.812Z","linkquality":194,"soil_moisture":27,"temperature":21.8,"temperature_unit":"fahrenheit"}'
info 2025-01-22 07:41:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:41:22.448Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:41:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:41:33.480Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:41:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:41:33.592Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:41:53z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:41:53.143Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:41:55z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:41:55.112Z","linkquality":196,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":234}'
info 2025-01-22 07:41:56z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fenster Schlafzimmer oben', payload '{"battery":97,"contact":true,"device_temperature":23,"last_seen":"2025-01-22T06:41:56.331Z","linkquality":199,"power_outage_count":75,"trigger_count":0,"voltage":2995}'
info 2025-01-22 07:41:57z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:41:57.338Z","linkquality":199,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":234}'
info 2025-01-22 07:42:00z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:41:59.997Z","linkquality":194,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":234}'
info 2025-01-22 07:42:07z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:42:07.330Z","linkquality":200,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:42:12z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Schreibtisch Maike', payload '{"last_seen":"2025-01-22T06:42:12.935Z","linkquality":191,"state":"OFF","update":{"installed_version":16909577,"latest_version":16909577,"state":"idle"},"update_available":false}'
info 2025-01-22 07:42:21z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:42:21.229Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":229}'
info 2025-01-22 07:42:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:42:22.623Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":230}'
info 2025-01-22 07:42:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:42:33.719Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:42:33z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:42:33.847Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:42:36z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Fenster Schlafzimmer unten', payload '{"battery":100,"contact":true,"device_temperature":22,"last_seen":"2025-01-22T06:42:36.089Z","linkquality":194,"power_outage_count":40,"trigger_count":0,"voltage":3005}'
info 2025-01-22 07:42:38z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S LED', payload '{"last_seen":"2025-01-22T06:42:38.762Z","linkquality":200,"state":"OFF","update":{"installed_version":16909577,"latest_version":16909577,"state":"idle"},"update_available":false}'
info 2025-01-22 07:43:07z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:43:07.489Z","linkquality":189,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:43:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:43:22.765Z","linkquality":193,"power":0,"power_outage_memory":"off","state":"OFF","voltage":230}'
info 2025-01-22 07:43:26z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:43:26.015Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:43:34z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:43:33.973Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:43:34z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:43:34.101Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:43:43z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Temp Filament', payload '{"battery":80,"humidity":22.1,"last_seen":"2025-01-22T06:43:43.709Z","linkquality":198,"temperature":16.3}'
info 2025-01-22 07:44:07z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:44:07.649Z","linkquality":197,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:44:08z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:44:08.096Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:44:10z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:44:09.985Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:44:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:44:22.908Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","voltage":230}'
info 2025-01-22 07:44:34z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:44:34.213Z","linkquality":197,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:44:34z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:44:34.324Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":234}'
info 2025-01-22 07:44:42z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Temp Filament', payload '{"battery":80,"humidity":22.1,"last_seen":"2025-01-22T06:44:42.347Z","linkquality":197,"temperature":16.3}'
info 2025-01-22 07:45:07z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:45:07.871Z","linkquality":200,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
info 2025-01-22 07:45:14z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lichtsensor Büro 1', payload '{"battery":100,"detection_period":5,"device_temperature":25,"illuminance":0,"last_seen":"2025-01-22T06:45:14.056Z","linkquality":198,"power_outage_count":13,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":3001}'
info 2025-01-22 07:45:15z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c13865b26b5553', payload '{"child_lock":"UNLOCK","current":0.05,"energy":0,"indicator_mode":"off/on","last_seen":"2025-01-22T06:45:15.641Z","linkquality":198,"power":0,"power_outage_memory":"off","state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"voltage":234}'
info 2025-01-22 07:45:23z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Heizstein', payload '{"current":0,"energy":349.61,"indicator_mode":"off/on","last_seen":"2025-01-22T06:45:23.071Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","voltage":230}'
info 2025-01-22 07:45:34z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:45:34.441Z","linkquality":201,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":233}'
info 2025-01-22 07:45:34z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/P1S Plug', payload '{"child_lock":"UNLOCK","current":0,"energy":62.97,"indicator_mode":"off","last_seen":"2025-01-22T06:45:34.586Z","linkquality":200,"power":0,"power_outage_memory":"off","state":"OFF","update":{"installed_version":268514823,"latest_version":268514823,"state":"idle"},"update_available":false,"voltage":233}'
info 2025-01-22 07:45:39z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Spülmaschine', payload '{"current":0,"energy":169.18,"indicator_mode":"off/on","last_seen":"2025-01-22T06:45:39.630Z","linkquality":201,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
xxx shortet xxx
this is for example the kitchen temp sensor:
Is its a bad idea to manually connect the sensor?
what is the difference between “interview” (blue i) and “new configure” (orange arrows)?
what is the best way to connect the devices again?
I am a little bit lost, because it seams random what isnt working
Edit:
this is one of the failure messages…
