I have
- Raspberry Pi 4 with HAOS and Home Assistant:
- Core - 2024.12.5
- Supervisor - 2024.12.0
- Operating System - 14.1
- Conbee II with the following firmware: 0x26580700.
I configured it using Zigbee2mqtt and this is how my config file looks like:
homeassistant:
enabled: true
advanced:
network_key:
pan_id: 22908
ext_pan_id:
log_level: debug
channel: 11
mqtt:
server: mqtt://core-mosquitto:1883
user: addons
password: __PASS__
serial:
port: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_XXXXXXX-if00
adapter: deconz
baudrate: 57600
frontend:
port: 8099
version: 5
availability:
enabled: true
The Z2M addon starts properly with the following logs:
[14:10:40] INFO: Preparing to start...
[14:10:40] INFO: Socat not enabled
[14:10:41] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-12-29 14:10:53] info: z2m: Logging to console, file (filename: log.log)
[2024-12-29 14:10:53] debug: z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2024-12-29 14:10:53] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2024-12-29 14:10:53] debug: z2m: sd-notify loaded
[2024-12-29 14:10:53] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-29 14:10:53] debug: z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":22908,\"extendedPanID\":[---],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{\"baudRate\":57600,\"path\":\"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DEXXXXXXX-if00\",\"adapter\":\"deconz\"},\"adapter\":{\"disableLED\":false}}"'
[2024-12-29 14:10:55] debug: zh:deconz:driver: Set delay to 0
[2024-12-29 14:10:55] debug: zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":22908,"extendedPanID":[---],"channelList":[11]},"serialPort":{"baudRate":57600,"path":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DEXXXXXXX-if00","adapter":"deconz"},"adapter":{"disableLED":false},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2024-12-29 14:10:55] debug: zh:deconz:driver: Opening with /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DEXXXXXXX-if00
[2024-12-29 14:10:55] debug: zh:deconz:driver: Serialport opened
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 1 paramId: 5
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: PANID: 597c
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 2 paramId: 11
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: APS_EXT_PANID: 0xdee5f888426a19ce
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 3 paramId: 28
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: CHANNEL: 11
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 4 paramId: 24
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: NETWORK_KEY: hidden
[2024-12-29 14:10:55] debug: zh:deconz:driver: send write parameter request from queue. seqNr: 5 paramId: 19 param: 5,2,5,0,0,32,0,1,4,5,1,0,25,0,10,6,0,0,0,5,1,0,5,1,4,1,0
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: write parameter response - parameter id: 19 - status: 0
[2024-12-29 14:10:55] debug: zh:controller: Started with result 'resumed'
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 6 paramId: 5
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 7 paramId: 11
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 8 paramId: 28
[2024-12-29 14:10:55] debug: zh:controller: Injected database: true, adapter: true
[2024-12-29 14:10:55] debug: zh:controller:device: Request Queue (0x00212effff05e61e): default expiration timeout set to 0
[2024-12-29 14:10:55] debug: zh:controller:database: Writing database to '/config/zigbee2mqtt/database.db'
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read parameter request from queue. seqNr: 9 paramId: 1
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: MAC: 0x00212effff05e61e
[2024-12-29 14:10:55] info: z2m: zigbee-herdsman started (resumed)
[2024-12-29 14:10:55] debug: zh:deconz:driver: send read firmware version request from queue. seqNr: 10
[2024-12-29 14:10:55] debug: zh:deconz:frameparser: read firmware version response - version: 0,7,88,38
[2024-12-29 14:10:55] info: z2m: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":88,"product":0,"revision":"0x26580700","transportrev":0},"type":"ConBee2/RaspBee2"}'
[2024-12-29 14:10:55] debug: z2m: Zigbee network parameters: {"channel":11,"extendedPanID":"0xdee5f888426a19ce","panID":22908}
[2024-12-29 14:10:55] info: z2m: Currently 0 devices are joined.
[2024-12-29 14:10:55] info: z2m: Zigbee: disabling joining new devices.
However, I’m not able to pair any device. I permit to join devices in Z2M, set paring mode in a device and nothing happened and there are no logs related to pairing.
I tried to use Conbee II with my PC and everything works fine so the dongle is working fine.
I also used this before in a similar configuration and it works. The only changes are:
- prob a different version of HAOS
- prob a different version of Z2M
- SSD used instead of SD card
I connected the SSD via SATA-USB3 adapter to Raspberry PI.
I tried to connect Conbee II via USB 3 and USB 2 with a 1m cable extension and without it.
Does anyone have any clues as to why this is not working? Is there something I can check more to find the root cause?
