I have been trying for some time to get Zigbee working with a ConBee3 on my HA. Unfortunately with no success.
I’ve already read a lot of forum posts and have got as far as getting the Zigbee2MQQT to work.
My TuYa plug is also recognized. I was looking forward to this, but unfortunately too soon.
It is recognized, but I can’t switch anything.
The strange thing is that when I connect the ConBee directly to my Windows computer with the DeCONZ, the TuYa is found and I can also control it.
In HA only this error message appears:
I also do not get the power consumption displayed.
Here is some more information about my config:
homeassistant: true
advanced:
network_key:
- 127
- 119
- 105
- 98
- 91
- 109
- 26
- 151
- 179
- 146
- 225
- 12
- 198
- 129
- 38
- 201
pan_id: 24225
ext_pan_id:
- 34
- 224
- 80
- 187
- 220
- 121
- 103
- 178
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: HAMQTT
password: XXX
keepalive: 60
reject_unauthorized: true
version: 4
serial:
port: /dev/ttyUSB0
adapter: deconz
baudrate: 115200
frontend:
port: 8099
device_options:
legacy: false
devices:
'0xa4c138e786e67b02':
friendly_name: '0xa4c138e786e67b02'
The Zigbee2MQTT protocol looks like this:
[10:01:14] INFO: Preparing to start...
[10:01:14] INFO: Socat not enabled
[10:01:14] ERROR: Got unexpected response from the API: Service not enabled
[10:01:14] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-02-10 10:01:16: Logging to console and directory: '/config/zigbee2mqtt/log/2024-02-10.10-01-16' filename: log.txt
Zigbee2MQTT:info 2024-02-10 10:01:16: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-10 10:01:16: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:info 2024-02-10 10:01:16: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2024-02-10 10:01:16: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":79,"product":0,"revision":"0x264f0900","transportrev":0},"type":"ConBee3"}'
Zigbee2MQTT:info 2024-02-10 10:01:16: Currently 1 devices are joined:
Zigbee2MQTT:info 2024-02-10 10:01:16: 0xa4c138e786e67b02 (0xa4c138e786e67b02): TS011F_plug_1 - TuYa Smart plug (with power monitoring) (Router)
Zigbee2MQTT:info 2024-02-10 10:01:16: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-02-10 10:01:18: Connecting to MQTT server at mqtt://core-mosquitto:1883
Zigbee2MQTT:info 2024-02-10 10:01:18: Connected to MQTT server
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: Started frontend on port 8099
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00212effff0e16f8/connection_state/config', payload '{"device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x00212effff0e16f8_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00212effff0e16f8/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00212effff0e16f8_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0x00212effff0e16f8/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0x00212effff0e16f8_restart_zigbee2mqtt"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0x00212effff0e16f8/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["info","warn","error","debug"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00212effff0e16f8_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00212effff0e16f8/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00212effff0e16f8_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00212effff0e16f8/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00212effff0e16f8_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00212effff0e16f8/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0x00212effff0e16f8_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00212effff0e16f8/permit_join_timeout/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"device_class":"duration","entity_category":"diagnostic","name":"Permit join timeout","object_id":"zigbee2mqtt_bridge_permit_join_timeout","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00212effff0e16f8_permit_join_timeout_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ iif(value_json.permit_join_timeout is defined, value_json.permit_join_timeout, None) }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0x00212effff0e16f8/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","device":{"hw_version":"ConBee3 0x264f0900","identifiers":["zigbee2mqtt_bridge_0x00212effff0e16f8"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.35.3"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00212effff0e16f8_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/switch/0xa4c138e786e67b02/switch/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138e786e67b02/set","device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"name":null,"object_id":"0xa4c138e786e67b02","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_switch_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/power_outage_memory/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:power-settings","name":"Power outage memory","object_id":"0xa4c138e786e67b02_power_outage_memory","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_power_outage_memory_zigbee2mqtt","value_template":"{{ value_json.power_outage_memory }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/select/0xa4c138e786e67b02/power_outage_memory/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138e786e67b02/set/power_outage_memory","device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"entity_category":"config","icon":"mdi:power-settings","name":"Power outage memory","object_id":"0xa4c138e786e67b02_power_outage_memory","options":["on","off","restore"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_power_outage_memory_zigbee2mqtt","value_template":"{{ value_json.power_outage_memory }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/indicator_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"enabled_by_default":false,"name":"Indicator mode","object_id":"0xa4c138e786e67b02_indicator_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_indicator_mode_zigbee2mqtt","value_template":"{{ value_json.indicator_mode }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/select/0xa4c138e786e67b02/indicator_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138e786e67b02/set/indicator_mode","device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"name":"Indicator mode","object_id":"0xa4c138e786e67b02_indicator_mode","options":["off","off/on","on/off","on"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_indicator_mode_zigbee2mqtt","value_template":"{{ value_json.indicator_mode }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"0xa4c138e786e67b02_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/current/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"device_class":"current","enabled_by_default":false,"entity_category":"diagnostic","object_id":"0xa4c138e786e67b02_current","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_current_zigbee2mqtt","unit_of_measurement":"A","value_template":"{{ value_json.current }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","object_id":"0xa4c138e786e67b02_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_voltage_zigbee2mqtt","unit_of_measurement":"V","value_template":"{{ value_json.voltage }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/energy/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"device_class":"energy","enabled_by_default":true,"object_id":"0xa4c138e786e67b02_energy","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"total_increasing","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_energy_zigbee2mqtt","unit_of_measurement":"kWh","value_template":"{{ value_json.energy }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/lock/0xa4c138e786e67b02/child_lock/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0xa4c138e786e67b02/set/child_lock","device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"name":"Child lock","object_id":"0xa4c138e786e67b02_child_lock","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_lock":"LOCK","payload_unlock":"UNLOCK","state_locked":"LOCK","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","state_unlocked":"UNLOCK","unique_id":"0xa4c138e786e67b02_child_lock_zigbee2mqtt","value_template":"{{ value_json.child_lock }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0xa4c138e786e67b02_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/sensor/0xa4c138e786e67b02/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"0xa4c138e786e67b02_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/binary_sensor/0xa4c138e786e67b02/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"0xa4c138e786e67b02_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'homeassistant/update/0xa4c138e786e67b02/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0xa4c138e786e67b02"],"manufacturer":"TuYa","model":"Smart plug (with power monitoring) (TS011F_plug_1)","name":"0xa4c138e786e67b02","via_device":"zigbee2mqtt_bridge_0x00212effff0e16f8"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/0xa4c138e786e67b02","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/0xa4c138e786e67b02","name":null,"object_id":"0xa4c138e786e67b02","origin":{"name":"Zigbee2MQTT","sw":"1.35.3","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0xa4c138e786e67b02\"}","state_topic":"zigbee2mqtt/0xa4c138e786e67b02","unique_id":"0xa4c138e786e67b02_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Zigbee2MQTT:info 2024-02-10 10:01:18: MQTT publish: topic 'zigbee2mqtt/0xa4c138e786e67b02', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":227,"power":null,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":233}'
Zigbee2MQTT:info 2024-02-10 10:01:18: Zigbee2MQTT started!
Zigbee2MQTT:info 2024-02-11 10:51:29: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2024-02-11 10:51:31: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"value":true},"status":"ok"}'
Zigbee2MQTT:error 2024-02-11 10:52:02: Publish 'set' 'state' to '0xa4c138e786e67b02' failed: 'Error: Command 0xa4c138e786e67b02/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (4))'
Zigbee2MQTT:info 2024-02-11 10:53:03: MQTT publish: topic 'zigbee2mqtt/0xa4c138e786e67b02', payload '{"child_lock":null,"current":null,"energy":null,"indicator_mode":null,"linkquality":227,"power":null,"power_outage_memory":null,"state":"ON","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":233}'
Zigbee2MQTT:error 2024-02-11 10:53:29: Publish 'set' 'state' to '0xa4c138e786e67b02' failed: 'Error: Command 0xa4c138e786e67b02/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (5))'
Zigbee2MQTT:error 2024-02-11 18:19:52: Publish 'set' 'state' to '0xa4c138e786e67b02' failed: 'Error: Command 0xa4c138e786e67b02/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (140))'
Zigbee2MQTT:info 2024-02-11 18:34:01: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-02-11 18:34:03: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":false},"status":"ok","transaction":"t3iwj-1"}'
Zigbee2MQTT:error 2024-02-11 18:35:15: Publish 'set' 'state' to '0xa4c138e786e67b02' failed: 'Error: Command 0xa4c138e786e67b02/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (no response received (146))'
Chris
