Zigbee2MQTT with the Aqara DJT11LM
I am new to HA and have recently added an Aqara DJT11LM to Zigbee2MQTT it paired fine and is working with vibration etc in HA, the problem I have is that it doesn’t appear to be updating/displaying the angles or the XYZ in Zigbee2MQTT.
Any ideas on where to start trouble shooting this would be helpful as it is the angle and xyz axis sensors that I want to be able to use.
I don’t have one of these to be able to check for you, but have a look here in case you find something which helps you out
Looks like it is an issue with zigbee2MQTT 1.40.2, see here
Same issue since updating to 1.40.2-1. Did a rollback to 1.40.1-1 to resolve the issue.
