pepe2
(Pepe)
March 3, 2024, 2:25pm
1
I rebuild a home assistant machine on a proxmox vm. I try to setup zigbee2mqtt and I get each time an error.
if i use zha then everything is working fine and I can connect zigbee devices.
But I can’t setup zigbee2mqtt.
What do I have to do, to setup zigbee2mqtt ?
francisp
(Francis)
March 3, 2024, 2:34pm
2
What dongle are you using ?
pepe2
(Pepe)
March 3, 2024, 2:35pm
3
sonoff 3.0 usb dongle plus
francisp
(Francis)
March 3, 2024, 2:36pm
4
You did disable ZHA ? Because you can’t use ZHA and Zigbee2MQTT at the same time with the same dongle.
pepe2
(Pepe)
March 3, 2024, 2:39pm
5
I see that remark on different sites, but I don’t know where to find it, to disable ZHA.
francisp
(Francis)
March 3, 2024, 2:46pm
6
Settings → Devices & Integrations → Zigbee → 3 dots
pepe2
(Pepe)
March 3, 2024, 2:52pm
7
Sorry, but I don’t have a zigbee integration anymore, I deleted when I had ZHA.
Show your Z2M config. It cannot find your dongle, that’s why it isn’t starting. It’s either in use or configured wrong.
francisp
(Francis)
March 3, 2024, 3:00pm
9
Since ZHA worked, I guess you properly passed-trough the dongle from proxmox to your vm.
Did you try these:
pepe2
(Pepe)
March 3, 2024, 3:04pm
11
this is my hardware setup.
and this is my zigbee2mqtt config:
Seems correct - can you verify that the port is listed as the same in configuration.yaml in the zigbee2mqtt folder?
francisp
(Francis)
March 3, 2024, 3:08pm
13
You have an EZSP dongle, not a ZSTACK one.
add
adapter: ezsp
to the serial
the Plus-V2 is the dongle-E, the Plus without V2 is the dongle-P
pepe2
(Pepe)
March 3, 2024, 3:15pm
15
Yes, Yes Yes: Thanks to Francisp the adapter: ezep was the solution.
But I never saw that I need the adapter to fill in.
123
(Taras)
March 3, 2024, 3:40pm
16
Please mark francisp’s post with the Solution tag because that’s the one that provided the solution to your problem.
