I tried several options already, but still can’t start it.
I have CC2531 stick that I flashed using this link
At the moment I have this confing
"external_converters": [],
"devices": [
"devices.yaml"
"groups": [
"groups.yaml"
"homeassistant": true,
"permit_join": false,
"mqtt": {
"base_topic": "zigbee2mqtt",
"user": "addons",
"password": "",
"server": "mqtt://core-mosquitto:1883"
"serial": {
"port": "/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDCED16-if00",
"adapter":"ezsp",
"baudrate":115200,
"rtscts": true
"advanced": {
"log_level": "warn",
"pan_id": 6754,
"channel": 11,
"network_key": [
1,
3,
5,
7,
9,
11,
13,
15,
0,
2,
4,
6,
8,
10,
12,
13
"availability_blocklist": [],
"availability_passlist": []
"device_options": {},
"blocklist": [],
"passlist": [],
"queue": {},
"frontend": {
"port": 8099
"experimental": {},
"availability": false
and get this error
[2024-10-20 19:52:39] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-10-20 19:52:39] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
[2024-10-20 19:52:54] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-10-20 19:52:54] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
[2024-10-20 19:53:14] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-10-20 19:53:14] error: zh:ezsp:ezsp: Connection attempt 3 error: Error: Failure to connect
[2024-10-20 19:53:39] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-10-20 19:53:39] error: zh:ezsp:ezsp: Connection attempt 4 error: Error: Failure to connect
[2024-10-20 19:53:39] error: z2m: Error while starting zigbee-herdsman
[2024-10-20 19:53:39] error: z2m: Failed to start zigbee
[2024-10-20 19:53:39] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-20 19:53:39] error: z2m: Exiting...
[2024-10-20 19:53:40] error: z2m: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:364:19)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:186:13)
at EZSPAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:152:16)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
tried w/o baudrate and rtscts.
I also tried to change adapter to another one (just did it randomly), for example with ember adapter I get this one
[2024-10-20 20:03:04] error: z2m: Error while starting zigbee-herdsman
[2024-10-20 20:03:04] error: z2m: Failed to start zigbee
[2024-10-20 20:03:04] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-10-20 20:03:04] error: z2m: Exiting...
[2024-10-20 20:03:04] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1583:24)
Any suggestions?
EDIT:
As I understood I need to use “zstack” adapter. But then I have this error
[2024-10-20 20:09:25] error: zh:zstack:znp: Failed to determine if path is valid: 'Error: spawn udevadm ENOENT'
[2024-10-20 20:09:26] error: z2m: MQTT error: getaddrinfo ENOTFOUND core-mosquitto
[2024-10-20 20:09:26] error: z2m: MQTT failed to connect, exiting... (getaddrinfo ENOTFOUND core-mosquitto)
[2024-10-20 20:09:27] error: z2m: MQTT error: getaddrinfo ENOTFOUND core-mosquit```
