Zigbee2MQTT: Wrong device_class for distance of Tuya presence sensor
I have experienced the inconvenience that the distance of my Zigbee presence sensors from Tuya https://www.zigbee2mqtt.io/devices/ZY-M100-24G.html do neither have a device_class nor a unit in Home assistant.
As far as I understand Zigbee2MQTT just sends the json payload and the interpretation happens somewhere in HA.
The payload looks like this
    "distance": 0,
    "illuminance_lux": 62,
    "linkquality": 65,
    "move_sensitivity": 2,
    "presence": false,
    "presence_sensitivity": 2.5,
    "presence_timeout": 5,
    "radar_range": 5.5,
    "state": "none"
When checking the debug information of the device in HA, illuminance_lux is set correctly with device_class, unit_of_measurement and state_class:
availability:
  - topic: zigbee2mqtt/bridge/state
    value_template: '{{ value_json.state }}'
device:
  identifiers:
    - zigbee2mqtt_0xa4c138b62a647ced
  manufacturer: Tuya
  model: 24G MmWave radar human presence motion sensor (ZY-M100-24G)
  via_device: zigbee2mqtt_bridge_0x00124b00258d4e6f
device_class: illuminance
enabled_by_default: true
object_id: presence/küche_illuminance_lux
origin:
  support_url: https://www.zigbee2mqtt.io
  sw_version: 1.40.1
state_class: measurement
state_topic: zigbee2mqtt/Presence/Küche
unique_id: 0xa4c138b62a647ced_illuminance_lux_zigbee2mqtt
unit_of_measurement: lx
value_template: '{{ value_json.illuminance_lux }}'
platform: mqtt
However, distance is missing these settings:
availability:
device:
  identifiers:
  manufacturer: Tuya
object_id: presence/küche_distance
origin:
  sw_version: 1.40.1
unique_id: 0xa4c138b62a647ced_distance_zigbee2mqtt
value_template: '{{ value_json.distance }}'
platform: mqtt
That makes for example the history more or less useless:
2024-09-10 09_54_10-Window
The question is: Does anyone have an idea how to add/edit this information? There is probably a workaround with an additional template sensor, but the cleaner solution would be to fix the configuration.
