Zigbee2mqtt xiaomi sensor will not reconnect without manual intervention
I’m using a CC2531 and xiaomi sensors. I have a sensor in the attic that doesn’t stay connected. Originally I installed it and it ran for about a week and then disconnected. I then replaced the battery and unpaired/repaired it. After that it ran again for about another week and then disconnected. Today I tried unplugging the CC2531 and reconnecting it to some how wake it up but that didn’t do anything.
Its strange because after I stop receiving data from it, it stops completely. It’s not even intermittent (like every few hours). It has now been silent for a few days straight. I’m pretty sure if I get it from the attic and fiddle with it then it will work again for a short time.
Is it a range issue? Does the device disconnect itself if the signal strength isn’t good and then turn itself off? How do I go about reconnecting it without having to climb into the attic?
Thanks for any help on this.
Suggest you open an issue on the zigbee2mqtt github.
