🧯 Zigbee2MQTT - ZemiSmart ZM-RM02 Controller
(18 actions!!) This Blueprint uses the Z2M (Zigbee2MQTT) imported Action sensor to sort out the 18 commands from the 6 buttons of a ZemiSmart ZM-RM02 Controller. The split out of functions gives you the ability to assign local scripts or functions to do the things you want the remote to do. Functions that are left empty will simply do nothing.
:bookmark_tabs: Changelog
  • 2024-06-04: Blueprint Input Sections for enhanced Descriptions.
  • 2023-08-07: Updates for Home Assistant 2023.8
    • Selector syntax change
    • Condition Selector addition (where applicable)
    • MQTT Discovery name changes (where applicable)
    • Clean-up code formatting
  • 2023-07-17: Adjust trigger-to statement
  • 2023-03-01: Add Author Tag. Bump HA required Version to 2023-3-0
  • 2022-12-12: Add Update Method Note, minor code change.
    • Name of Blueprint may have changed meaing you have to re-download with a new link.
    • If name changed, it is similar. Variables have not changed.
  • 2022-05-05: Updated for 2022.5.0 HA. Added Markdown to !input Descriptions.
  • 2022-04-17: :tada: :control_knobs: :battery: New Blueprint!
:crystal_ball: About this blueprint
Type of blueprint: AUTOMATION
What if I am having problems getting it going?
You can contact me for help, see the links below.
Why do I need this?
:wrench: Configuration
Requirements
  • My 'suggestion' is that you do separate scripts for most, if not all of the actions you generate here. If you are using the UI editor for the simple things you are fine, but for more complicated things scripts may work better for you. This is my opinion and how I am using it, to each their own. Building functions within the uI is also available if you are more comfortable with that.
  • To make the Blueprint work you will need a functional RM02 integrated to Home Assistant thru Zigbee2MQTT and find the sensor entity in the Home Assistant Device tab that Z2M imported which is named similar this:
    • sensor.xxDevice_Namexx_action
    • Open your Home Assistant instance and show your devices.
If you do not see that sensor, 'LegacyAPI' might not be selected in the Zigbee2MQTT settings - settings - advanced menu. Please find and check/select that setting like so:
-- SCROLL DOWN --
:card_index_dividers: Input fields
remote/name: Remote
    The entity to put here is the sensor that Z2M imported that is
    named like this ->  ```sensor.XXYour_HameXX_action```'
additional_conditions:
    Extra conditions you may want to add to this automation
    (Example: Home occupied, TV on, etc)
tap_1:
  name: Single click on Button 1 action
doubletap_1:
  name: Double click on Button 1 action
hold_1:
  name: LongPress on Button 1 action
tap_2:
  name: Single click on Button 2 action
doubletap_2:
  name: Double click on Button 2 action
hold_2:
  name: LongPress on Button 2 action
tap_3:
  name: Single click on Button 3 action
doubletap_3:
  name: Double click on Button 3 action
hold_3:
  name: LongPress on Button 3 action
tap_4:
  name: Single click on Button 4 action
doubletap_4:
  name: Double click on Button 4 action
hold_4:
  name: LongPress on Button 4 action
tap_5:
  name: Single click on Button 5 action
doubletap_5:
  name: Double click on Button 5 action
hold_5:
  name: LongPress on Button 5 action
tap_6:
  name: Single click on Button 6 action
doubletap_6:
  name: Double click on Button 6 action
hold_6:
  name: LongPress on Button 6 action
:wrench: It won't work.. Are my Button presses working?
There is sample code to make the template sensor in the help file on GitHub Repo.
Within this blueprint there is an event handler that will latch the last command that the blueprint finds and sends that to the event buss. From there a simple Template sensor can grab it and show you the last action sent. This will help when setting up new functions and to troubleshoot strange behaviors. Add an entity card in your dashboard for sensor.cube_last_action to see what actions occur as you press the buttons.
Yaml file that contains the sample code here
:sun_with_face: :snowflake: Troubleshooting tip
If you are troubleshooting and you want to see more traces back when doing so, here is a TIP I've found.
Manually edit the automation created with the ui editor (or manually with a text editor) and add the following to have this automation contain 10 traces instead of the normal 5. Then if the automation is triggering often, you can see the last 10 traces to help you decide what the issue is.
HA Docs on this here.
trace:
  stored_traces: 10
:envelope_with_arrow: Version Updates
Updates will be published on my GIT repository with the rest of my Home Assistant Blueprint collection.
:envelope_with_arrow: There is not an official version control system for Blueprints. However I have found something that comes pretty close. It is not perfect, but for MOST Blueprints, it does just fine. I encourage you to check this script out and use it to easily check if I have updated this blueprint. :link:koter84 Blueprint Update Script
Please Click the :orange_heart: at the end of this top Post if you find this Useful
:mobile_phone_with_arrow: Software to Download :floppy_disk:
HA link to download blueprint: Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
Direct link to download Blueprint: https://github.com/SirGoodenough/HA_Blueprints/blob/master/Automations/Zigbee2MQTT-ZemiSmart_ZM-RM02_Controller.yaml
:globe_with_meridians: All My Blueprints
Link to ALL my Blueprints
https://github.com/SirGoodenough/HA_Blueprints/blob/master/README.md
:man_juggling:t5: Contact Links or see my other work
What are we Fixing Today Homepage / Website: https://www.WhatAreWeFixing.Today/
Channel Link URL: (WhatAreWeFixingToday) https://bit.ly/WhatAreWeFixingTodaysYT
Discord Guild: (Sir_Goodenough#9683) WhatAreWeFixingToday?
:cheese_wedge: If you want to support me
Buy me Coffee: https://www.buymeacoffee.com/SirGoodenough
PayPal one-off donation link: PayPal.Me
#WhatAreWeFixingToday
#SirGoodEnough
@DMcG
I prefer to answer in the main thread as opposed to DM…
The sensor will be in Home Assistant, not the Z2M control page.
Find the switch in Devices and you should see the sensor name there.
Thank you for this. I had looked in the devices tab and it wasn’t there. However, seeing your MQTT logo on the screenshot pointed me in the correct direction. I had set MQTT up when I started with HA a few weeks ago and hadn’t properly configured it (as didn’t really need it at the time). Deleted and reconfigured MQTT, restarted HA and I can see everything now.
Thank you so much.
    • (Documentation change 2-7-2024 to add License notice. Changes only to Descriptions.)
Why do I need this?
:moai:License Notice:
  • Copies of the original Blueprint that were converted via the 'Take Control' feature or other means are officially not supported by me.
  • I may or may not be able to support you when you have a problem after you make changes to my code, as some of the code is no longer mine.
  • I & my license also require attribution as a link back to the original should you use this code in your own creation.
  • Here is a link to my license & the original github post expected to be followed & referenced as attribution should you use this code elsewhere.
Requirements
-- SCROLL DOWN --
remote/name: Remote
tap_1:
doubletap_1:
hold_1:
tap_2:
doubletap_2:
hold_2:
tap_3:
doubletap_3:
hold_3:
tap_4:
doubletap_4:
hold_4:
tap_5:
doubletap_5:
hold_5:
tap_6:
doubletap_6:
hold_6:
trace:
  stored_traces: 10
#SirGoodEnough
Z2M version 2.x has dropped. This means if you install that, you will need to make a change to your configuration in order to use :fire_extinguisher: Zigbee2MQTT - ZemiSmart ZM-RM02 Controller.
I have not yet made changes to accommodate for the update, and my changes are going to be likely using the Home Assistant experimental event entities.
So to accommodate the change, I will be asking you to change 2 buttons in the Z2M :gear: set-up screen in the User Interface (UI) screen.
Please click both these:
Home Assistant legacy action sensors So that it will work now until I update this and
Home Assistant experimental event entities for later so it works after I update this.
Also leave Enabled checked as well. It should look similar to that photo when you are done.
Sorry for any inconvenience this is causing you. I wanted the dust to settle a bit so that I could see the final version of the change before I updated my stuff. In the end I think this is a positive change and will make programming these devices a lot easier for everyone.
