Zigbee2QMTT loses philips light for remote
Hello! I tryed to connect a philips ensis light into HAOS (system) through Zigbee2MQTT. All OK. The Sonoff ZB Donglee-E works perfectly. But then I loose the remote. If I try to reconnect the remote, HAOS loses the connection to the light.
Core mosquito still sees it. But not Zigbee2QMTT. (I don’t use Philips HUB if that makes a difference)
Is there a way to have both connections working at once?
