Hi all,
Since a couple of days, the Ziggo Connect Box (UPC_Connect) integration stopped working for me. The Home Assistant logs shows the following debug log:
2020-08-28 17:57:25 DEBUG (MainThread) [connect_box] Receive http code 302
I’m wondering if more people are facing this issue. The component worked perfectly fine for me for several years. The request seems to get redirected (hence the 302) to the login page, which might be because the token that it is using is invalid.
I have raised an issue for it here. Please add a thumbs up to the opening post here in case you are facing the same issue: https://github.com/home-assistant/core/issues/39300
Thanks!
