@Veldkornet it should update everytime you switch from a channel. If you switch channels with the remote it doesn’t work, it only keeps track of the channel selected through HA.
@Rosiaantje glad to hear you like it! I haven’t figured out how to start it from sleep mode, so I just disabled the eco mode in settings so it always stays standby. (blue light)
@arjenotto You could try to see if the logging says something useful, maybe even enable debug level so you get additional logging. I don’t get notifications on this thread because I’m not the topic starter, so without a mention I have no clue someone says something here. But i’ll try to help you if possible.
@IIStevowII, I’m quite new with the Raspberry Pi and hass.io. In your instructions you wrote:
Download the content of this repository
Place the directory “ziggo-mediabox-next” in the “custom_components” directory of your Home Assistant installation.
I cannot find the “custom_components” directory via the Samba share. I only see addons, backup, config, share and a ssl directory. I’ve searched in these but no trace of a custom_components directory. Can you please tell me how to locate it?
@robertwebbe if you haven’t installed any custom components yet you have to make the folder manually. Just create an folder in the folder where your configuration.yaml is located. Looking @ what you wrote that would be in your config folder.
I’ve created the folders, copied the content, added the code to the configuration.yaml file (with my Ziggo account credentials) and rebooted.
Now I get the error “Integration ziggo-mediabox-next not found when trying to verify its media_player platform.” The Mediabox Next is switched on and playing.
What do I miss?
EDIT: I already found out what I did wrong, I created the custom_components folder myself and copied the whole bunch in it. In the data was also the folder custom_components. I’ve moved it up and now the error is gone
Failed to get platform media_player.ziggo-mediabox-next
File "/usr/src/homeassistant/homeassistant/config.py", line 795, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 235, in get_platform
"{}.{}".format(self.pkg_path, platform_name)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/ziggo-mediabox-next/media_player.py", line 9, in <module>
from homeassistant.components.media_player import (PLATFORM_SCHEMA, MEDIA_PLAYER_SCHEMA)
ImportError: cannot import name 'MEDIA_PLAYER_SCHEMA' from 'homeassistant.components.media_player' (/usr/src/homeassistant/homeassistant/components/media_player/__init__.py)
Hi guys, I created a new component, based on Stevens, that support multiple boxes. It’s far from finished. But it’s a start. I will add some more features shortly. Feel free to join development or submit feature requests or issues.
Got this error after installing Stevowll’s component. What to do? ziggo-mediabox-next: Error on device update! Traceback (most recent call last): File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 292, in _async_add_entity await entity.async_device_update(warning=False) File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 441, in async_device_update await self.hass.async_add_executor_job(self.update) File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/Users/Thuis/.homeassistant/custom_components/ziggo-mediabox-next/mediabox_next.py", line 158, in update self._client.start() File "/Users/Thuis/.homeassistant/custom_components/ziggo-mediabox-next/mqtt_client.py", line 78, in start self._client.connect(DEFAULT_HOST, DEFAULT_PORT) File "/Users/Thuis/.homeassistant/deps/lib/python/site-packages/paho/mqtt/client.py", line 839, in connect return self.reconnect() File "/Users/Thuis/.homeassistant/deps/lib/python/site-packages/paho/mqtt/client.py", line 994, in reconnect sock.do_handshake() File "/Library/Frameworks/Python.framework/Versions/3.7/lib/python3.7/ssl.py", line 1139, in do_handshake self._sslobj.do_handshake() ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1076)
