They work and report back Volts, Amps, Power Factor & Power. HA will switch them On & Off but does not reflect there status, i.e. if you manually switch the socket “Off” via the local switch HA still shows it being “On”
I got mine yesterday and initially it found the device, but none of the entities showed up using ZHA.
After a reboot the entities all appeared, but power factor shows unknown and both apparent power and ac frequency is blank.
I can confirm that if the power button is used on the plug, the status is not reflected in HA.
There were reports of randomly switching off.
Apparently this is because the device has surge protection at 250v.
However, in the UK, the declared voltage and tolerance for an electricity supply is 230 volts -6%, +10%. This gives an allowed voltage range of 216.2 volts to 253.0 volts.
My voltage is currently hovering in the 247 to 249 range, so suspect it occasionally peaks over, and the device trips.
Arrgh! Have contacted their support to see if there is a way to configure a the cut-off to meet with UK defied tolerances.
My understanding is the newer firmware was supposed to address that issue. If you find outc that’s not the case, please do let me know as I’ve peaked over 250v 16 times in 2022 so far
I had noticed that both mine had turned themselves off, but had not got around to the cause, the over voltage explains it. My mains often goes above 250V
What’s worse is the two issues combine,
When it does switch off due to a surge, it still reports as on - so you cannot detect the failure and switch it back on.
I am not that familiar with Zigbee2mqtt. It found them but it did not self populate in HA.
I think the big issue is them turning themselves off, so I will be contacting the supplier about this tomorrow, if enough people raise it as an issue maybe it will be sorted by a firmware update (if that is possible)
I have just tested one of these plugs with a calibrated Fluke Multi-meter and can confirm that the socket did turn itself off when the voltage reached 250.5V, the voltage needed to be high for a few seconds, so just not a short spike.
I have just received mine and set it up via Zigbee2MQTT. I cant find any issue so far.
I power on and off at the plug and i see this in HA as well. I see all the amps and voltage info as well. I dont see a firmware version listed in Zigbee2MQTT though
Hi. Yes if i turn the switch on and off via its physical button i see this reflected in HA and then of course HA on and off switches the plug on and off.
What i am seeing is that the plug is not always reporting the power and current values. The device plugged inn should be pulling about 700w
