when I start HA I get a log entry that is extremely strange:
"Logger: zigpy.config.validators
Source: components/zha/init.py:151
First occurred: 2:12:21 PM (1 occurrences)
Last logged: 2:12:21 PM
The z2m_index key is deprecated, migrate your configuration to the extra_providers list instead: `extra_providers: [{‘type’: ‘z2m’}]"
my ZHA config:
zha:
zigpy_config:
ota:
enabled: true
# Periodically send out a network-wide (including end devices!) image notification
broadcast_enabled: true
broadcast_initial_delay: 14400
broadcast_interval: 14400
# Points to Z2M OTA `index.json` URL
z2m_remote_index: "https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/index.json"
network:
channel: 15 # What channel the radio should try to use.
channels: [15, 20, 25] # Channel mask
ZHA dcs basically says now to not use any advanced OTA configuration unless you are a developer and know what you are doing (because flashing unofficial device firmware from Z2M can brick devices).
Refer to zigpy documentation for OTA configuration for more information on additional OTA providers:
So this means I just have to remove the ota config altogether and everything should work fine?
This kinda feels “wrong” since we always needed some kind of ota config in ZHA and I thought I was using the “new one” which actually did work since it finally gave me some updates for a few of my devices.
But I’ll just go and comment the ota config out.
Yes that is correct. Unless you want to disable OTA for some brands, then you can add what is the ZHA docs now to disable OTA for each of those supported brands:
zha:
zigpy_config:
ota:
ikea_provider: false # Disable OTA update downloads for Trådfri devices
inovelli_provider: false # Disable OTA update downloads for INOVELLI devices
ledvance_provider: false # Disable OTA update downloads for LEDVANCE/OSRAM devices
salus_provider: false # Disable OTA update downloads for SALUS/Computime devices
sonoff_provider: false # Disable OTA update downloads for Sonoff (ITead) devices
thirdreality_provider: false # Disable OTA update downloads for 3REALITY devices
Again, if you want to enable z2m OTA downloads then you can still do so via advanced zigpy config but it not recommend and therefor no longer in the there by default and no longer info about it in ZHA docs.
With this, I currently get updates announced for my Sonoff TRVs. But when just deleting all this in my configuration.yaml (like advised) and restart, HA says: There are no updates available.
Assuming that HA is not taking this source for the updates, I tried to force to use the one I used above:
But: After restarting HA, still no updates available.
So what should I do? I stumpled over this because OTA-updates take very long or aren’t possible at all because it seems that HA is timing-out, but I couldn’t find any explanation for the parameters like broadcast_interval.
sorry again for the extreme delay in answering.
I am currently using:
zha:
zigpy_config:
network:
I don’t see any errors in my log but then again I don’t have any “special” URLs I need to pull updates from. (plus my devices are all quite old and don’t really get any new updates)
