ZigStar Lan GW issue with Hue Motion SML001
Hi all,
I recently installed Homeassistant again in docker on my synology with a zigstar Lan GW firmware 0.6.10. Everything seems to work alright with HA autodetecting the zigstar as a zha. I then managed to add all my hue devices, seeing them appear on the default dashboard.
The only issue i have is with the hue motion sensors SML001.
Once added they give me various entities including:
  • Motion
  • Occupancy
  • Illuminance
Now the wierd thing, some sensors have the Occupancy entity permanently set as “clear”, using only motion to indicate detection. When detecting motion they set the Motion entity to “Detected”, only to return to “clear” 5minutes later. The little T button hidden under the back toggles the Motion entity as well.
Other motion sensors seem to have the motion entity permanently set as “clear”, only toggling it with the T button. Here the Occupancy entity does work, switching to “detected” when motion is seen, and going back to “clear” only seconds later.
All seem to be having issues updating the Illuminance entity, with it staying put at whatever level it was initialised with.
Does anyone have a clue whats going on? I added the motion sensors back to the Hue bridge, but all are running the same and latest firmware.
