I recently got my Zigbee 3.0 USB Dongle-E and was looking at videos regarding flashing the FW.
I found this video as some others have mentioned in this forum already and I believe i followed the steps correctly, however it’s worth mentioning that Bearded Tinker used a Dongle-P vs a Dongle-E which is what I had, hence me having to use the Silicon Labs flasher. It seems me navigating to the correct link for the firmware, I’m getting an error that it’s not valid or correct.
Here’s a copy of the log:
Add-on: ZigStar Silicon Labs FW Flasher
ZigStar Silicon Labs firmware flasher add-on
Add-on version: 0.1.1
You are running the latest version of this add-on.
System: Home Assistant OS 15.0 (amd64 / generic-x86-64)
Home Assistant Core: 2025.3.4
Home Assistant Supervisor: 2025.03.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[12:40:20] INFO: Starting universal-silabs-flasher with /dev/ttyUSB0 (bootloader baudrate 115200)
2025-03-22 12:40:21 193f5383-zigstar-silabs-flasher asyncio[155] DEBUG Using selector: EpollSelector
Error: '/root/firmware.gbl' does not appear to be a valid GBL image: ValidationError('Image is truncated: tag value is cut off')
[12:40:21] INFO: universal-silabs-flasher-up script exited with code 1
s6-rc: warning: unable to start service universal-silabs-flasher: command exited 1
s6-rc: info: service banner: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
`type or paste code here`
The URL in question is this one:
https://github.com/Koenkk/Z-Stack-firmware/raw/refs/heads/master/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20240710.zip
As can be seen from this screenshot:
Any help would be greatly appreciated
