I recommend on using last firmware: XZG - Web Flasher - XZG Firmware
Now Koenkk released stable firmware,you should upgrade .
Z-Stack firmware was under havy development by Koenkk,but now is finally released,so is very stable.
Donāt want to sound too negativeā¦ Hmmm released and very stable? thatās why there is an issue open named āI believe there is an issue with Z-stack 20240710 FWā with tons of entries?
Or would this be considered normal and stable and weāre just hearing from the 1% with problems and 99% are happy? (Canāt have my wife unhappyā¦)
I know you are not involved in the development of Z-Stack.
FYI, I have upgraded since yesterday (stable in the last 24 hours) to the latest Z-stack version 20240710 (that is actually from Aug26) but still the LQI and RSSI are not displayed correctly in ZHA.
I think this issue is more related with the ZHA integration rather than Koenkkās Z-stack firmware, as long as in Z2M are displayed correctly.
I will log a new request there.
yeah,i see now.
Yeah,you can revert to older firmware,but in most cases i didnt receive any report of any issues.
yeah,you are righ.
Iām not involved in development of firmware - only testing before release.
I had an issue which I resolved by reading through the Discord and thought i would share here as well.
UZG-01 POE version straight out of the box and did a firmware update via web interface OTA, the ESP32 worked, the zigbee hung and then ended up with ? for the zigbee version. Tried multi tool via USB and get Timeout waiting for ACK/NACK after āSynch (0x55 0x55)ā. And yes, did follow the guide to hold button 4-10 seconds to get in USB mode.
After reading the discord went to the web interface and then the Zigbee page, clicked co-ordinator, then clicked Iām sure. It then updated the firmware and rebooted and all working with the firmware version now showing on the status page. Hope this helps someone else.
Hi what router are you using? How is your experience with the router(stable connection without drop out?)
