ZigStar - ZigBee Coordinators and Routers
Hi there — I placed an order a few days ago. Did you receive it? Thanks. PayPal says that the order has not yet been processed.
I am in pain because my ZiGate device simply drops packets on the floor every day with only 31 ZigBee devices and I think your device is going to solve my problem.
Hi,for all order related questions drop an email or check zig-star.com contact page.
Email sent.
When there will be stock for the lan versions?
Hi,yes,we are back to stock today.
Does the ZigStar LAN Gateway - ZigStar (zig-star.com) comes by default with case/box? or is just the board?
At the moment i didnt have time to arrange 3D Printing ,so unfortunately without case.
Hi, I have been using the ZIGSTAR Lan gateway for a while now and I am very pleased with it. My one annoyance is I cannot work out how to turn off the ZIGSTARGW-9607 wifi network. I have the GW Multitool which discovers the gateway – where is the option to turn off the Wifi hotspot ? Many Thanks
Hi,you access zigstar by browser,there is a lot of options for LAN/WIFI.
There you will be able to disable wifi.
I just wanted to come back to this thread and say that the ZigStar device has been frickin awesome, all my problems I had with ZiGate are totally gone, and Radu is very knowledgeable and trustworthy. Thanks Radu!
Bought a LAN Gateway and Stick V4.
First timer, got both up and running with not much issue (other than not RTFM) using Z2M, will stick with the LAN Gateway and keep the Stick V4 as a backup.
Item was posted quickly, and in the DHL system, but took over 2 weeks to arrive in the UK.
Unfortunately i can’t do express shipping, prices change to often so i stick to standart prices from DHL
Hi, when the ZigStar OliZig PoE will be available ?
Hi,I’m back from vacation.
Is currently available.
Welcome back!
@mercenaruss
Hi, I need some advice because I am planning to buy a PoE-capable LAN coordinator.
I see on the zigstar website that there are several versions.
Which one would you recommend if it is only needed for a wired network without WiFi?
I can’t do 3D printing, how can I get a box?
Tank you for your help.
steve
Hi! Is there a way to integrate the temperature of the LilyZig board into the Home Assistant?
Will be available hopefully this week,on website and github. But will not be final release.
Yes,you just need to setup MQTT from webinterface of device and will appear in your instance.
@mercenaruss
Thank you very much for your help. It would be very important for me with the PoE LAN coordinator box, because it has to be placed in a boiler house and there is a lot of humidity in the room.
Where should I look for it so I don’t miss it?
You did a great job, thank you.
