Hoping this is the right area to post this in.
I have had the Zimi integration for some time now and what has happened over the last six or so months is that every time I upgrade HA or even just reboot, the Zimi integration fails. It usually comes good by itself but it can take up to a week or two sometimes and it is getting frustrating.
From the log files:
Home Assistant Core
2023-05-15 16:20:12.683 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration zimi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-05-15 16:21:15.703 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: zimi, samsungtv, smartthings
2023-05-15 16:21:53.757 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ZIMI Controller for zimi
File "/config/custom_components/zimi/__init__.py", line 30, in async_setup_entry
File "/config/custom_components/zimi/controller.py", line 94, in connect
Has anyone else had this problem and is there anywhere to report this?
I have tried rebooting the Zimi gateway but no go.
I am guessing that one option is to remove and re-integrate but before I try that, I thought I would ask the gurus here for advice what to try.
Any advice would be most gratefully received.
Thanks in advance.
