Greetings.
I would appreciate help with powerstrip configuration for ESPHome. I got covered every relay switch, the only thing eludes me is a POWER BUTTON (which is a binary sensor): it requires a script, which toggles all sockets ON and OFF simultaneously. I went with lambdas: on_click I check if retrieved state is ‘true’, turn all sockets off, publish_state(id) to ‘false’ and vice versa. I got it to this part:
binary_sensor:
- platform: gpio
pin: 3
on_click:
min_length: 50ms
max_length: 500ms
then:
lambda: !lambda |-
if (id(pwr).state) {
id(zld_44eu_w_relay1).turn_off();
id(zld_44eu_w_relay2).turn_off();
id(zld_44eu_w_relay3).turn_off();
id(zld_44eu_w_relay4).turn_off();
id(zld_44eu_w_relay_usb).turn_off();
id(pwr).publish_state(false);
} else {
id(zld_44eu_w_relay1).turn_on();
id(zld_44eu_w_relay2).turn_on();
id(zld_44eu_w_relay3).turn_on();
id(zld_44eu_w_relay4).turn_on();
id(zld_44eu_w_relay_usb).turn_on();
id(pwr).publish_state(true);
I got GPIOs right, so I’m clearly missing something in the code, because button toggles power on once by double-clicking and not working at all after that. Single click doesn’t work at all, plus once sockets are on, they won’t switch off via the button, only though HA interface. Where am I wrong exactly?
Thank you in advance.
nickrout
(Nick Rout)
May 31, 2020, 8:43pm
2
There is a sample code here https://esphome-configs.io/devices/brilliant-smart-powerboard/
It does more than you want, but may give inspiration.
Thank you kindly, dear Sir!
I totally missed the idea that lambda condition checks are the same with C++
Plus, I misiterpreted button states, so for me this piece of code goes like this:
binary_sensor:
- platform: gpio
pin: 3
internal: true
on_press:
lambda: |-
if (! (id(zld_44eu_w_relay1).state || id(zld_44eu_w_relay2).state || id(zld_44eu_w_relay3).state || id(zld_44eu_w_relay4).state || id(zld_44eu_w_relay_usb).state)) {
} else {
“If any of the relays are on - turn everything off, otherwise - turn everything on”
Now I have to realise how to restore relays to previous condition individually, not turn them on all at once.
nickrout
(Nick Rout)
June 1, 2020, 8:13am
4
Glad you got it sorted. I claim no credit for the code though. I copied it from another config.
hey @YujiTFD i finally managed to flash this strip with esphome. would you mind sharing your full config for this device?
Hi there.
You message caught me on the train station, leaving city for a day I will return by Wednesday, stay in touch.
Hello again.
Full code below. Again, it’s a single-click logic “If any of the relays are on - turn everything off, otherwise - turn everything on”:
esphome:
platform: ESP8266
board: esp8285
esp8266_restore_from_flash: false
wifi:
ssid: !secret wifi_ssid_liot
password: !secret wifi_password_liot
fast_connect: on
ap:
ssid: "ZLD_44EU_W Fallback Hotspot"
# password: !secret ap_password
captive_portal:
# Enable logging (NONE, ERROR, WARN, INFO, DEBUG, VERBOSE, VERY_VERBOSE)
logger:
level: DEBUG
baud_rate: 0
esp8266_store_log_strings_in_flash: false
# Enable Home Assistant API
api:
# password: !secret esphome_api_password
ota:
# password: !secret esphome_ota_password
web_server:
port: 80
status_led:
pin: 1
binary_sensor:
- platform: gpio
pin: 3
internal: true
on_press:
lambda: |-
} else {
switch:
- platform: gpio
pin: 5
icon: mdi:power-socket-eu
restore_mode: RESTORE_DEFAULT_ON
- platform: gpio
pin: 4
- platform: gpio
pin: 12
- platform: gpio
pin: 13
- platform: gpio
pin: 14
inverted: yes
icon: mdi:usb
