Hi all,
Just switch from domoticz to HA and I am missing some infos.
In domoticz I had much more info like current, power in kw !
But more than that there was the “Alarm” sensor. The most important that trigger just before the linky will trip (I found that there is about 12 seconds to react.
It was the best info for me as this alarm is the real signal of overload seen by the facility network. It is usualy at a much higher value than my contract limit and is integration some buffer.
It is much more interesting than the max contract limit.
I can of course remove load when it is above my contract but it is not going to be optimized, it will balance the load much earlier than with alarm sensor.
Is there a way to add this value in ZHA plugin ?
Laurent
