I have an old ZME-UZB1 Zwave controller USB key which I have plugged into the PC and installed the driver (it shows as “UZB (COM2)” within the devices list of windows under Ports (COM & LPT) and not as a USB device.
On the PC I have installed a Hyper-V instance on HA. I have installed the ZWave JS plugin, however when going to select the the device from within the ZWave JS plugin it does not list it. Nor is the device listed within the detected hardware.
Hyper-V is set to passthrough host devices so not sure why I cant see it in HA.
Anyone any ideas of what I need to do to see it?
If all else fails I will order a new 700 controller but dont want to do that if I dont need to or I will have the same problem.
Thanks in advance!
