Zodiac E30iQ pool pump
Hello everyone,
I have just purchased a Zodiac E30iQ pool pump and I want to integrate it into my Home Assistant setup. I have already connected my pump to the Fluidra Connect app.
Has anyone successfully integrated this specific model?
If you have any tips, tutorials, or configuration files to share, I would appreciate it.
Thank you in advance for your help.
Hi, did you already conduct a search here on the forum or in a search engine?
There seems not to be any information about this in the integrations or on the net in relation to HA.
Maybe someone else might know more but be aware about this that it’s a good idea to check if a device works with HA before buying it.
hi, yes, I’ve already done several searches and couldn’t find anything, which is why I’m asking for help. I was given this pump as a gift, so I didn’t have a choice regarding the model.
Hey!
I’ve just released a Home Assistant integration for Fluidra/Zodiac pool equipment, which I developed by reverse-engineering the Fluidra Connect API.
:link: GitHub Repository:
https://github.com/foXaCe/Fluidra-pool.git
:white_check_mark: What works (tested on my E30iQ pump):
  • Full pump control: on/off, speeds (Low 45%, Medium 65%, High 100%)
  • Automatic mode: smart management with schedules (up to 8 slots/day)
  • Manual mode: direct speed control
  • Real-time sensors: current speed, mode, status, active schedules
  • Perfect synchronization with the Fluidra Connect mobile app
:hammer_and_wrench: How it works:
The integration connects directly to Fluidra’s AWS servers (the same backend as the mobile app).
