I see a new menu item in HA 0.76.2, Configuration/Integrations called Zones. It appears to let me define a zone and when I do, it does indeed show up on my map but… I cannot find the file the definition is kept in, I cannot edit one that I create here and it doesn’t show my existing defined zones from my standard .yaml file.
Is this some new “undocumented feature”, something not completed yet or something to be ignored?
Its been a part of hass for a few releases. You can just remove it and add a new with your altered values. The option to modify integrations is not yet developed. If you necessarily need to modify its stored version you can find it under .storage/core.config_entries
I’ll not use the “integrations” mode until they manage to have all zones grouped under a single Integration menu item. I have plenty of zones and it will be a mess having each one listed in “Integration”
Its on the roadmap to redo zones, having them as part of integrations was a mistake
