Is there a way to add a wild card in from a zone trigger from a certain geolocation source,
For example I defined a custom zone equivalent of the range of my ADS-B SDR and want to set up a trigger to notify me of any plane that flies over that zone.
something like
zone: zone.flightairmap_tracking
event: enter
entities: geolocation.flightairmap.*
- data_template:
message: '{{trigger.from_zone.name}} plane spotted in your area'
title: Alert
service: notify.notify
I understand that is completely wrong but that’s the general consensus of it
So does it create a new entity? The format geolocation.flightairmap. isn’t correct for an entity_id. Can you provide a screenshot of the entity that is created by this?
Well best I can offer is a “what planes are inside this zone” sensor. Outside of that, I can’t think of anything that would do this.
sensors:
planes_in_zone:
value_template: >
{% set radius = state_attr('zone.home', 'radius') | int / 1000 %}
{% set ns = namespace(inside=[]) %}
{% for gl in states.geo_location if gl.object_id.startswith('flightairmap') and distance(gl.entity_id) < radius %}
{% ns.inside = ns.inside + [ gl ] %}
{% endfor %}
{{ ns.inside | map(attribute='name') | join(', ') if gl | length > 0 else 'Empty' }}
This will watch for any geo_location state change, and add the plane to the list. THen you can use this sensor to make triggers. But you’ll get notifications when leaving or entering.
Now if you only want entering…
sensors:
planes_in_zone:
value_template: >
{% endfor %}
{{ ns.inside | count }}
attribute_templates:
latest: >
{% set current = state_attr('sensor.planes_in_zone', 'planes').split(', ') %}
{% endfor %}
{{ ns.inside | rejectattr('name', 'in', current) | map(attribute='name') | first }}
planes: >
{% endfor %}
{{ ns.inside | map(attribute='name') | join(', ') }}
Then in your automation…
- alias: Notify entering planes.
- platform: state
entity_id: sensor.planes_in_zone
condition:
condition: template
value_template: >
{{ trigger.to_state != None and trigger.from_state != None and
trigger.to_state.state | int > trigger.from_state.state | int }}
Theres a very good chance this doesn’t work out of the box because I haven’t tested any of it.
This is my automation for planes entering a custom zone named “plane_far”. It then just currently sends a message to my slack channel #planes with the name of the plane.
- alias: Planes
platform: geo_location
source: flightairmap_feed
zone: zone.plane_far
# Event is either enter or leave
event: enter # or "leave"
- service: notify.slack
message: "Plane in far zone {{ trigger.to_state.name }}"
- "#planes"
My zone “plane_far” is also set as passive so it still uses my home zone for my other automation involving my home.
This is just adapted from the automation page documentation.
Awesome! So I think I just overthought it and by not specifying a specific name you in turn are just saying all planes?
Learning more and more every day!!
