I updated to 0.80 and I am getting the following error for Zoneminder. Also none of the cameras are showing up
2018-10-15 12:28:31 ERROR (SyncWorker_31) [zoneminder.zm] JSON decode exception caught while attempting to decode "<br /> <b>Fatal error</b>: Uncaught Error: Call to undefined function apc_fetch() in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php:91 Stack trace: #0 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(363): ApcEngine->read(‘myapp_cake_core…’) #1 /usr/share/zoneminder/www/api/lib/Cake/I18n/I18n.php(235): Cache::read(‘cake_dev_eng’, ‘cake_core’) #2 /usr/share/zoneminder/www/api/lib/Cake/basics.php(636): I18n::translate(‘Cache engine "%…’, NULL, ‘cake_dev’) #3 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(184): __d(‘cake_dev’, ‘Cache engine "%…’, ‘cake_core’) #4 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine(‘cake_core’) #5 /usr/share/zoneminder/www/api/app/Config/core.php(375): Cache::config(‘cake_core’, Array) #6 /usr/share/zoneminder/www/api/lib/Cake/Core/Configure.php(72): include(‘/usr/share/zone…’) #7 /usr/share/zoneminder/www/api/lib/Cake/bootstrap.php(442): Configure::bootstrap(true) #8 /usr/share/zoneminder/www/api/app/webroot/index.php(90): includ in <b>/usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php</b> on line <b>91</b><br /> " Traceback (most recent call last): File “/usr/local/lib/python3.6/site-packages/zoneminder/zm.py”, line 90, in _zm_request return req.json() File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 896, in json return complexjson.loads(self.text, **kwargs) File “/usr/local/lib/python3.6/site-packages/simplejson/init.py”, line 518, in loads return _default_decoder.decode(s) File “/usr/local/lib/python3.6/site-packages/simplejson/decoder.py”, line 370, in decode obj, end = self.raw_decode(s) File “/usr/local/lib/python3.6/site-packages/simplejson/decoder.py”, line 400, in raw_decode return self.scan_once(s, idx=_w(s, idx).end()) simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0) 2018-10-15 12:28:31 WARNING (SyncWorker_31) [zoneminder.zm] Could not fetch monitors from ZoneMinder 2018-10-15 12:28:31 WARNING (SyncWorker_31) [homeassistant.components.sensor.zoneminder] Could not fetch any monitors from ZoneMinder 2018-10-15 12:28:31 ERROR (SyncWorker_32) [zoneminder.zm] JSON decode exception caught while attempting to decode "<br /> <b>Fatal error</b>: Uncaught Error: Call to undefined function apc_fetch() in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php:91 Stack trace: #0 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(363): ApcEngine->read(‘myapp_cake_core…’) #1 /usr/share/zoneminder/www/api/lib/Cake/I18n/I18n.php(235): Cache::read(‘cake_dev_eng’, ‘cake_core’) #2 /usr/share/zoneminder/www/api/lib/Cake/basics.php(636): I18n::translate(‘Cache engine "%…’, NULL, ‘cake_dev’) #3 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(184): __d(‘cake_dev’, ‘Cache engine "%…’, ‘cake_core’) #4 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine(‘cake_core’) #5 /usr/share/zoneminder/www/api/app/Config/core.php(375): Cache::config(‘cake_core’, Array) #6 /usr/share/zoneminder/www/api/lib/Cake/Core/Configure.php(72): include(‘/usr/share/zone…’) #7 /usr/share/zoneminder/www/api/lib/Cake/bootstrap.php(442): Configure::bootstrap(true) #8 /usr/share/zoneminder/www/api/app/webroot/index.php(90): includ in <b>/usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php</b> on line <b>91</b><br /> " Traceback (most recent call last): File “/usr/local/lib/python3.6/site-packages/zoneminder/zm.py”, line 90, in _zm_request return req.json() File “/usr/local/lib/python3.6/site-packages/requests/models.py”, line 896, in json return complexjson.loads(self.text, **kwargs) File “/usr/local/lib/python3.6/site-packages/simplejson/init.py”, line 518, in loads return _default_decoder.decode(s) File “/usr/local/lib/python3.6/site-packages/simplejson/decoder.py”, line 370, in decode obj, end = self.raw_decode(s) File “/usr/local/lib/python3.6/site-packages/simplejson/decoder.py”, line 400, in raw_decode return self.scan_once(s, idx=_w(s, idx).end()) simplejson.errors.JSONDecodeError: Expecting value: line 1 column 1 (char 0) 2018-10-15 12:28:31 WARNING (SyncWorker_32) [zoneminder.zm] Could not fetch monitors from ZoneMinder 2018-10-15 12:28:31 WARNING (SyncWorker_32) [homeassistant.components.camera.zoneminder] Could not fetch monitors from ZoneMinder 2018-10-15 12:28:37 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
