I was using zoneminder previously, but I switched to frigate.
So I removed the zoneminder section in the configuration.yaml.
But now, every reboot, there is a message in the log :
Error during setup of component zoneminder
File "/usr/src/homeassistant/homeassistant/setup.py", line 256, in _async_setup_component
result = await task
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/zoneminder/__init__.py", line 63, in setup
for conf in config[DOMAIN]:
KeyError: 'zoneminder'
And :
Unable to prepare setup for platform zoneminder.sensor: Unable to set up component.
Is there something else I need to remove to get rid of this error log ?
Thank you
