Zoneminder integration missing?
I’ve just updated to version 6.6 and my Zoneminder cameras have gone awol apparently because the Zoneminder integration has failed to initialise. I’ve been trying to find the original integration and it seems that it’s no longer available on HA (or HACS - can’t remember where I got it from now). Does anyone else have this problem? And has the integration been removed?
It sounds like you were expecting to find it in the UI. You should check the full list instead.
That’s highlighted to you in the UI search if you’ve enabled Advanced mode in your user profile, but sadly is otherwise hidden.
Advanced enabled and nothing showing. I’ve had Zoneminder integration for quite some time now without any issues but since upgrading the integration has broken and it’s not available via the UI. Hence I was thinking the integration has been removed. Not sure what’s going on here now!
Did you click the link I posted?
I did yes. It didn’t explain why Zoneminder has disappeared from the UI nor why my original integration has stopped working.
It’s never been in the UI :man_shrugging:
Can’t say why it’s not working for you, but the log file should help there. See the troubleshooting docs for guidance there.
It was setup a long time ago hence my memory fail… I don’t think my problem is with HA anyway. At this moment I’m certain that the Zoneminder APIs aren’t playing ball hence my issues - just in case anyone else comes across this thread
