Thanks man. Sorry if I’m coming across abrasive, this has just been causing me huge amounts of stress lately. I’ve invested in IP cameras and a PoE switch because various people on this forum have convinced me it’s a lot easier than it actually is.
I really appreciate your help.
Here’s my logs as they appear in the configuration menu.
Failed to connect http://192.168.0.20:8080/json, Error: 501, message="Unsupported method ('POST')", url=URL('http://192.168.0.20:8080/json'), Line: 89
22:42:37 – (ERROR) Blue Iris NVR (custom integration) - message first occurred at 24:38:51 and shows up 5977 times
The 'asuswrt' option near /config/configuration.yaml:2 is deprecated, please remove it from your configuration
22:37:26 – (WARNING) ASUSWRT - message first occurred at June 28, 2021, 01:58:17 and shows up 2 times
Error opening stream rtmp://192.168.0.20/live/annke_cam
22:13:18 – (ERROR) Stream - message first occurred at June 28, 2021, 01:58:58 and shows up 176 times
Update for camera.camera_1_fluent fails
22:10:03 – (ERROR) components/zoneminder/camera.py - message first occurred at June 28, 2021, 02:39:27 and shows up 32 times
Update of camera.camera_1_fluent is taking over 10 seconds
22:10:03 – (WARNING) helpers/entity.py - message first occurred at June 28, 2021, 02:39:27 and shows up 32 times
Update for camera.camera_1 fails
21:39:53 – (ERROR) components/zoneminder/camera.py - message first occurred at June 28, 2021, 03:58:18 and shows up 17 times
Unable to get API response from ZoneMinder
21:39:53 – (ERROR) /usr/local/lib/python3.8/site-packages/zoneminder/zm.py - message first occurred at June 28, 2021, 03:58:18 and shows up 49 times
Error while executing automation automation.frigate_zoneminder: required key not provided @ data['name']
20:12:27 – (ERROR) Automation - message first occurred at June 28, 2021, 07:01:45 and shows up 69 times
Frigate - Zoneminder: Error executing script. Invalid data for call_service at pos 1: required key not provided @ data['name']
[Dining Room TV(192.168.0.201):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.0.201', 8009)), retrying in 5.0s
14:13:00 – (ERROR) /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py - message first occurred at June 28, 2021, 02:16:19 and shows up 11 times
[Office speaker(192.168.0.83):8009] Heartbeat timeout, resetting connection
14:12:45 – (WARNING) /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py - message first occurred at June 28, 2021, 02:16:04 and shows up 16 times
Update for switch.camera_1_state fails
11:39:53 – (ERROR) components/zoneminder/switch.py - message first occurred at June 28, 2021, 03:58:18 and shows up 2755 times
Update for sensor.camera_1_status fails
11:39:52 – (ERROR) components/zoneminder/sensor.py - message first occurred at June 28, 2021, 03:58:18 and shows up 2748 times
Unable to connect to ZoneMinder
11:39:22 – (ERROR) /usr/local/lib/python3.8/site-packages/zoneminder/zm.py - message first occurred at 24:13:50 and shows up 17836 times
Could not fetch runstates from ZoneMinder
11:39:22 – (WARNING) /usr/local/lib/python3.8/site-packages/zoneminder/zm.py - message first occurred at 24:13:50 and shows up 1372 times
Could not get availability for monitor 1.
11:39:22 – (WARNING) /usr/local/lib/python3.8/site-packages/zoneminder/monitor.py - message first occurred at 24:13:50 and shows up 2744 times
Could not get status for monitor 1.
Error demuxing stream:
10:15:39 – (ERROR) Stream
RTP: PT=60: bad cseq e0d3 expected=d075
10:15:39 – (ERROR) components/stream/worker.py
Websocket connection failed, retrying in 15s: Cannot connect to host 192-168-0-20.c1d1d60ee1954e14a8660980e7bb3aba.plex.direct:32400 ssl:default [None]
10:15:32 – (ERROR) /usr/local/lib/python3.8/site-packages/plexwebsocket.py - message first occurred at 08:50:09 and shows up 4 times
Timeout error fetching information from http://192.168.0.20:5000/api/stats -
10:15:25 – (ERROR) Frigate (custom integration) - message first occurred at 08:00:15 and shows up 31 times
Disconnected from MQTT server 192.168.0.20:1883 (1)
10:14:55 – (WARNING) MQTT - message first occurred at 08:50:37 and shows up 7 times
Error fetching frigate data:
10:12:55 – (ERROR) Frigate (custom integration) - message first occurred at 08:00:15 and shows up 4 times
Could not connect to Plex server: NATEFLIX (HTTPSConnectionPool(host='192-168-0-20.c1d1d60ee1954e14a8660980e7bb3aba.plex.direct', port=32400): Read timed out. (read timeout=30))
08:49:12 – (ERROR) Plex Media Server
Cannot complete login
01:02:08 – (WARNING) Blue Iris NVR (custom integration) - message first occurred at 24:38:51 and shows up 5 times
Failed to access BlueIris Server (192.168.0.20)
Error requesting RT-AC87U data: Cannot connect to host 192.168.0.1:40493 ssl:default [Connect call failed ('192.168.0.1', 40493)]
24:15:58 – (ERROR) UPnP/IGD
https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned 503
June 28, 2021, 22:58:39 – (ERROR) /usr/local/lib/python3.8/site-packages/metno/__init__.py
Resource connection failed to plex.tv: Microsoft Edge
June 28, 2021, 16:34:17 – (ERROR) Plex Media Server
http://192.168.0.20:32400: Client not found at http://192.168.0.20:32400
June 28, 2021, 16:34:17 – (ERROR) /usr/local/lib/python3.8/site-packages/plexapi/myplex.py - message first occurred at June 28, 2021, 16:34:17 and sh
