Unable to prepare setup for platform zoneminder.sensor: Unable to set up component.
8:14:37 PM – setup.py (ERROR) - message first occurred at 8:14:33 PM and shows up 2 times
Error setting up entry for hacs
8:14:37 PM – components/frontend/__init__.py (ERROR)
Error during setup of component zoneminder
8:14:33 PM – components/zoneminder/__init__.py (ERROR)
I have just tried this integration and initially I had similar issues as the OP.
It turned out that the ZM user has to have “API Enabled” set to yes to make it work.
Before using this integration, I have tried manually to connect cameras (RTSP) to lovelace. The live stream had huge lag and nothing helped to reduce it. But this integration works well.
