I’m having an issue with the Hass.io Zoneminder component. I set up the component and switch.
I can see the camera in my front end and activating the switches send the correct functions to the correct cameras in ZM.
The problem I’m having is with Buffers.
No matter how large or small I make the “Image Buffer Size”, “Pre Event Image Count” or “Post Event Image Count”, ZM only records from about 1-2 seconds after the switch is activated and stops immediately when the switch is turned to off.
Also, setting it to Modect properly records both Pre and Post buffers.
I tried from Monitor to Record and from Nodect to Record but neither work.
Is there a setting I’m missing?
Thanks.
