On my iPhone/iPad, if I use safari and go to HA website, I can zoom with pinching, but chrome and the app do not zoom.
Is there a way to let the app zoom into camera streams or zoom in general?
Thanks.
Thanks.
Hi all, this should actually work on many browsers, or you can check the option in iOS app for example. But I noticed it didn’t work on Fully Kiosk Browser, for example. To fix that you can do the following:
Put this in a file called zoom-enable.js in your config/www folder
document.querySelector("meta[name=viewport]").setAttribute("content", "width=device-width, viewport-fit=cover");
Add this to your configuration.yaml:
frontend:
extra_module_url:
- /local/zoom-enable.js
Restart and bob’s your uncle.
In the iOS app’s App Configuration under General you can enable pinch-to-zoom without needing to inject JavaScript.
