ZooZ 4-in-1 MultiSensor Not Displaying Temp or Humidity
Hello! Recently I’ve had to reset hassio by reflashing the image on the SD card. For the most part everything came back except the Zooz sensor temperature and humidity. Both of those are showing 0. I’ve given it a few days and its still sitting at 0. I’ve tried using the zwave “wake up” mode on it and it’s still the same. The actualy motion sensor works perfectly, no problems there just not sure why temp and humidity aren’t refreshing. Any other ideas I could try?
Z-Wave devices send the data to the controller, so it sounds like the problem is with the sensor.
