I recently bought a ZooZ 4-in-1 sensor (temp, motion, humidity, light) and trying to get it setup with HASS.
I’ve got the sensor included from ozwcp, and it’s showing up as a Vision ZP3111 Multisensor 4in1, and I am able to see the Configuration items from within ozwcp. However, if I change one (such as Temperature Unit from C to F), which according to the documentation is Parameter 1, the value will switch back on it’s own in like 60 seconds. This happens when I try to change any of the parameters. Why does this happen?
Also, from HASS, I am only seeing binary_sensor.multisensor_kitchen_sensor_8 (I’ve renamed the sensor from ozwcp to multisensor_kitchen), as well as the [...]alarm_level_8 and [...]alarm_type_8. I am not seeing any entity ID’s for temperature, humidity, or anything else.
In fact, for binary_sensor.multisensor_kitchen_sensor_8, the only attributes listed are:
Sorry for the back to back post, but it seems that a lot of new sensors were showing up and the Configuration options have changed in ozwcp once I pressed the button on the multisensor several times.
Seems after a few minutes to catch up, I am now seeing my expected sensors and values within HASS. Guess my post was almost pointless, but in case anyone else runs into issues with a multisensor, just press the button on it several times to see if that gives it a jump start.
@russell I’m afraid I don’t fully understand your question (likely due to my lack of knowledge with Z-Wave). I have the motion, temperature, humidity, and light sensors working and reporting like I wanted in hass.
I did change some parameters from ozwcp, but I don’t think that it really had any impact on me getting things working.
I don’t get any changes to the motion sensor value, it stays off. I get changes to the “Alarm Level” and “Burglar” fields only. See for example this screenshot from zwcfg.
I also have the Zoos 4in1 multisensor and the motion sensor will not trigger. The temperature, luminance, and humidity items update as expected in HomeAssistant. I tried to get ozwcp working but gave up so I managed to change the motion sensitivity parameter on the device to “1” (ie. very sensitive) using Domoticz but still no luck. As a side note, it does not register motion in Domoticz or zVirtualScenes (Windows) either so I’m starting to suspect the issue is with the sensor.
I’m not sure what to say, other than the motion sensor is working for me. It’s the Burgular sensor that reports motion, and it reports in an on/off fashion. From what I gather, a value of 0 means no motion, and a value of anything else means motion. For me, it seems that the burglar sensor sets to a value of 8 when motion is detected, though I’m not sure why it changes to 8. I figured it would be a 0 for no motion, and 1 for motion, but whatever.
And all works as expected. Again, I am using open zwave control panel and I see the value hop from 0 to 8 when motion is detected, and my sensor has been working great for at least a week now.
Thanks tycoonbob! After I posted yesterday, I discovered that the ‘burglar’ sensor changes from 0 to 8 when it detects motion, too. I’m fairly new to HomeAssistant so I haven’t played around with templates yet - I like what tycoonbob did. In my case, I monitor the numeric_state for ‘burglar’ and my automation rule works as expected.
I just bought one of these and am having the same issue. However, a recent commit to the open-zwave repo a few days ago should fix this. The change might not make it into HA for a while, but you can edit your config file accordingly to fix. I’ll try to remember to report back once I get a chance to test.
anyone can give me a hint to change the config parameters of this device?
I just started with home assistant and zwave and bought one of these to play arround.
It works well but i wanted to disable the LEDs and play arround with the motion sensitivity but i cant get my changes to stick. I read that i have to wake up the device but i dont know how (tried opening the cover and pressing the small switch accessible from the outside.
im only using home assistant to configure the device, no additional z-wave software.
Update:
Ok it accapted the command now after a few hours.
I am having trouble adding this to my configuration.yaml file
Would you be able to post a screen shot of were you added this please.
I tried adding it to Sensor:
I am NOOB at this but trying to learn thanks
binary switch does not work at all (which I believe is normal, but then why show it)
The burglar sensor just shows unknown (never changes) or off, the only way I get anything to change is to reboot, then it seems stuck where it was last.
I’m about to throw these in the trash!! They worked fine with Smarthings (and I also had them briefly working with Hubitat). I’ve reset them, removed, readded. Added normal, added secure. They do report temp, and humidity, etc, but I really wanted a stable motion senor,I have like 10 temp sensors in my house, dont really need more.
Is there a trick to pairing these, they seem to go to sleep during the paring process. I have them less and 2 feet from the usb stick
I’ve actually had good luck with them. Mine are the v2 version. I, too, wanted a reliable stable motion sensor (the temp, humidity, and luminance are just bonuses for me). I came from SmartThings where I found their own branded Zigbee motion sensors pretty great. So I had a high bar. Based on the direction in this thread and through other research, I ended up adding them to Hass.io using the Zwave control panel’s “Add Secure” function. Then I had to push the button a few times to wake it up and finish the pairing process. I found it created a bunch of entities, most of which are nonsensical and utterly confused me. Then I found some guidance to use the template platform to create a motion sensor out of the values of the one entity that changes it value based on motion (IIRC, it goes from 0 for no motion to 255 for motion detected). It works perfectly. Here’s an example of one of mine:
When I asked Zooz support they responded that the default binary_sensor does not work in Hass:
It looks like the binary_sensor was used for the 300 series devices while notification is used for 500 devices to report motion. So if you look at the supported command classes in the manual, there is no binary sensor command class supported, but rather the notification command class for motion reports. […]
We double checked that the ZSE40 doesn’t report as binary_sensor and there is no way to enable these reports through a software update.
It sounds like your issue. I think the device only wakes up twice a day by default. Perhaps it just needs to complete pairing and keeps falling asleep before it finishes. Have you tried manually pushing the Zwave button on the device to manually wake it? A single click should do it according to the manual (http://www.getzooz.com/downloads/zooz-zse40-4-in-1-sensor-manual.pdf). May want to repeat that over the course of several minutes and watch your Zwave log to see what’s happening and if the additional entities show up.
it works well. keep in mind the following for anyone trying to use this sensor with home-assistant:
There are two versions of these: the monoprice and the zooz brand. they are identical.
The “button” that manuals refer to is a small hole in the bottom, click it with a clip. It is NOT the tamper detection switch inside the unit when you open it. This is not specified in the manual (monoprice)
To pair it double click the zwave button
after pairing if it is not complete after a minute or so and your entities dont show up. help it by “waking” it that is pressing the zwave button once
You have to use the alarm_level entity entity and use a template for the motion sensor. Like the posts above mention
For you to change parameters you have to “wake” it. Again that is pressing the button once. Keep in mind that it will be awake for 20 seconds only, so you need to be fast and do any changes within that window. You can wake it again to do others.
There is a bunch of entities that do nothing. feel free to hide them, looks like they were made for other devices using the same chipset.
