Zooz joins Works with Home Assistant
Our Works with Home Assistant program is expanding once again, and this time we’re excited to announce Zooz is joining us! We have tested many new devices of all different types, ensuring they provide the best experience possible with Home Assistant. As well as classic staples for the smart home, they also bring some very cool flood protection devices to help safeguard your home.
These will be the first certified Z-Wave devices added to the program in some time, and are just part of the exciting future the Home Assistant community and Zooz see for this smart home protocol.
Zooz zooms in
Zooz started out not as a manufacturer, but as a retailer of smart devices. They focused so much on customer support that they soon realized they could do a better job than manufacturers already in the market, and so turned instead to creating their own products. They focus on Z-Wave for its interoperability and security, and they include easy-to-understand installation guides with these devices. They also have a wide knowledge base on their website and a very responsive support team.
As Z-Wave experts, they’re members of the Z-Wave Alliance (where Paulus is also a member as the voice of the open source community). While Zooz is based in the USA, many of their products are available worldwide.
It takes Zooz
Zooz has really embraced the Home Assistant community. Agnes, their VP of Brand and Partnership Support, recently spoke to the team over at the Home Assistant podcast about their startup journey. She also came along to our Community Day in Brooklyn, hosted by our very own Product Lead, Madelena. It’s awesome to see manufacturers get out and connect with our community members.
"Zooz has been contributing quality hardware to the smart home community for over 10 years now and our biggest takeaway is that thoughtful integration is key for our customers. We recognize that our devices are part of an ecosystem and that's why we are so excited to partner with Home Assistant, a platform we highly respect for its commitment to making products work together seamlessly. I especially appreciate how quickly Home Assistant embraced Z-Wave Long Range and how easy it is to set up Z-Wave on a brand new system thanks to hardware like Home Assistant Green. We look forward to connecting with the Home Assistant community, learning together, and creating new devices driven by your feedback."
- Agnes Lorenz, VP, Brand and Partnership Support, Zooz.
Devices
In case you didn’t know, Works with Home Assistant differs from other certification programs as products are rigorously tested in-house to ensure they work seamlessly out of the box. Any company joining also commits to providing long-term support and firmware updates while being a positive force in the Home Assistant community. Works with Home Assistant is operated by the Open Home Foundation, and the support of Home Assistant Cloud subscribers funds this work.
Zooz has had a large group of devices certified, one of the largest number of devices we’ve ever certified for a launch into the program. Kudos to the foundation team, and Zooz for making such a great variety of new devices available to our community.
Leak Protection
ZAC36 Titan Water Valve Actuator
Plugs
ZEN04 Smart Plug
ZEN05 Outdoor Plug
Relays
ZEN16 Multi Relay
ZEN51 Dry Contact Relay
ZEN52 Double Relay
ZEN53 DC Motor Controller
Lighting Switches
ZEN30 Double Switch
ZEN32 Scene Controller
ZEN71 On Off Switch
ZEN72 Dimmer
ZEN74 Toggle Dimmer
ZEN76 S2 On Off Switch
ZEN77 S2 Dimmer
Sensors
ZSE11 Q Sensor (4in1)
ZSE18 Motion Sensor
ZSE41 Open / Close XS Sensor
ZSE42 Water Leak XS Sensor
ZSE43 Tilt Shock XS Sensor
ZSE44 Temperature Humidity XS Sensor
ZSE70 Outdoor Motion Sensor
Frequencies and firmware
If you’re based in North America, all new devices will come with Z-Wave Long Range (ZWLR) as standard. If you are based elsewhere, like in Europe, Long Range won’t be enabled quite yet. The reason is that even though the Z-Wave Long Range protocol has been available for some time in North America, it was only released in Europe in April 2025, as certification took a bit longer. The nice thing about Zooz’s North American 700 series and European 800 series Z-Wave, is that ZWLR can be enabled via an over-the-air (OTA) firmware update, so hopefully everyone will be taking part in the Z-Wave Long Range revolution soon. Watch this space for a not-so-secret Home Assistant Z-Wave hardware announcement coming your way…
Z-Wave Long Range opens up a whole new world of options and makes for an even more flexible smart home. Maybe you have a large backyard, or an awkwardly shaped long, but narrow home that is hard to get other protocols to cover adequately. Or perhaps you have devices that are just too far away for other protocols. A common example is wanting a way to get notified when the mailbox at the front of your driveway is opened or closed.
Many of the certified devices can function outdoors or be purchased with accessories to make them waterproof. Speaking on a personal note, we had a leak in our garage a year or so ago after some bad weather. Other protocols couldn’t reach that far, and we had no way to be notified. I cannot wait for an easy way to be notified across that bigger distance, and avoid all the unpleasant clean-up.
It’s great to read stories on social media or our forums where smart home devices have kicked in and saved the day, like getting that all-important notification or cutting off the water supply with something like Zooz’s valve actuator.
Z-Wave, like other open standards we support, works locally, and all of the devices listed above will work locally, without the need for any extra cloud connection or apps. Remember, if you’re also looking for remote access to make sure you don’t miss any critical notifications while you’re away from home, an easy way to get this set up is to subscribe to Home Assistant Cloud. Not only will this help you monitor your smart home remotely, but you’ll also be supporting the development of Home Assistant.
FAQs
Q: If I have a device that is not listed under “Works with Home Assistant” does this mean it’s not supported?
A: No! It just means that it hasn’t gone through a testing schedule with our team or doesn’t fit the requirements of the program. It might function perfectly well, but be added to the testing schedule later down the road, or it might work under a different connectivity type that we don’t currently test under the program.
Q: OK, so what’s the point of the Works with program?
A: It highlights the devices we know work well with Home Assistant and the brands that make a long-term commitment to keeping support for these devices going. The certification agreement specifies that the devices must have the expected functionality within Home Assistant, operate locally without the need for cloud, and will continue to do so long-term.
Q: How were these devices tested?
A: All devices in this list were tested using a standard HA Green Hub with our Z-Wave Integration. If you have another hub integration that’s not a problem, but we test against these as they are the most effective way for our team to certify within our ecosystem.
Q: Will you be adding more Zooz devices to the program?
A: Absolutely! We’re thrilled to foster a close relationship with the team at Zooz to work together on any upcoming releases or add in further products that are not yet listed here.
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2025/07/15/zooz-joins-works-with-home-assistant
This is great news! Zooz has always been my go-to for wireless devices in my house.
That’s a good and awesome news and I’m waiting the big one when the home assistant zwave stick to buy it i hope soon i really need zwave dongle
This is huge, ever since I “discovered” Zooz a few years ago, I exclusively use their products. They just work.
Zen16 but not Zen17?
Aside from the 17, all my other zooz devices are on the list! :+1:
Always loved how well the Z-Wave protocol works and I have more such devices than those using other protocols. Living in the EU though I do not have many Zooz devices, at least not yet.
The only downside to Z-Wave has always been the price per device, which I hope will get better now that it is more of an open standard and other manufacturers can make such chips too.
I agree with @Hedda , but would add:
Getting the correct frequency for use in the EU (or UK for me) can be difficult.
That is actually not quite true any longer with Z-Wave 700 series and Z-Wave 800 series based devices as with those newer chips the frequency is no longer hardcoded in the hardware chip, so as long as the antenna-design support a broader frequency range then the manufacturer can release the exact same hardware product globally in different RF regions with just a new firmware and certification for RF regions. This is also why manufacturers now can release the same Z-Wave Controller hardware in different RF regions as the user can set/change the RF region in software.
When will Zooz start selling more of its devices in Europe with shipping from within the European Union.
Any plans for Zooz to partner will other/more resellers in the EU instead only offering direct sales or Amazon?
Shipping from the USA to EU is too expensive because of tariffs, import taxes and higher shipping costs (which are also taxed).
Personally I am specifically interested in Z-Wave 800 Series mains-powered devices as well as Z-Wave Long Range battery-powered devices.
ZSE42 isn’t fully supported by ZWave JS UI for a few months. It’s missing new settings for Parameter 5. I looked into adding them, but the hex codes aren’t listed on Zooz docs. I’ve been in touch with tech support going in circles for a few days and figured out on my own that it wasn’t updated in the Zwave JS database.
What is the process for flagging devices that don’t fully “work with home assistant”?
Who is responsible for updating the device file, I’d suggest the manufacturer if they are certified?
Zwave js is, on their repo
Interesting… So by nature of being a Zwave product, couldn’t anything be “Works with Home Assistant” if they go through the cert. process?
I put together a PR to get it fixed, so it’s hopefully not an issue soon.
I guess I thought it made sense that if a manufacturer can claim “Works With Home Assistant” then they’d be responsible to keep the device files updated in Zwave JS, avoiding burden on OHF or the community to maintain.
