I have a new zooz 4 in 1 motion sensor. I’m trying to use HA to change the motion threshold from normal to High. I do what I believe the instructions say. I set the value in HA using the zwave configuration area. I press the program button on the zooz device but the HA screen just switches back to normal after a few seconds. I have tried changing to other settings as well with the same results. Here is a dump of the zwave log for the sensor in question. I have the vendor actively involved, but wanted to open a dialog on this on the HA side as well.
2017-12-27 12:29:13.559 Detail, Node098, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x62, 0x03, 0x20, 0x01, 0xff, 0x4d
2017-12-27 12:29:13.560 Info, Node098, Received Basic set from node 98: level=255. Sending event notification.
2017-12-27 12:29:13.560 Detail, Node098, Notification: NodeEvent
2017-12-27 12:29:13.580 Detail, Node098, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x62, 0x0a, 0x71, 0x05, 0x07, 0xff, 0x00, 0xff, 0x07, 0x08, 0x00, 0x00, 0xff
2017-12-27 12:29:13.580 Info, Node098, Received Alarm report: type=7, level=255, sensorSrcID=0, type:Burglar event:8, status=255
2017-12-27 12:29:13.581 Detail, Node098, Refreshed Value: old value=7, new value=7, type=byte
2017-12-27 12:29:13.581 Detail, Node098, Changes to this value are not verified
2017-12-27 12:29:13.582 Detail, Node098, Refreshed Value: old value=0, new value=255, type=byte
2017-12-27 12:29:13.582 Detail, Node098, Changes to this value are not verified
2017-12-27 12:29:13.583 Detail, Node098, Refreshed Value: old value=0, new value=0, type=byte
2017-12-27 12:29:13.584 Detail, Node098, Changes to this value are not verified
2017-12-27 12:29:13.584 Detail, Node098, Refreshed Value: old value=0, new value=8, type=byte
2017-12-27 12:29:13.585 Detail, Node098, Changes to this value are not verified
2017-12-27 12:29:13.586 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:13.620 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:13.652 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:13.680 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:15.635 Detail, Node098, Received: 0x01, 0x16, 0x00, 0x49, 0x84, 0x62, 0x10, 0x04, 0x07, 0x01, 0x5e, 0x86, 0x72, 0x5a, 0x85, 0x59, 0x73, 0x80, 0x71, 0x31, 0x70, 0x84, 0x7a, 0x45
2017-12-27 12:29:15.636 Info, Node098, UPDATE_STATE_NODE_INFO_RECEIVED from node 98
2017-12-27 12:29:15.636 Detail, Node098, AdvanceQueries queryPending=1 queryRetries=0 queryStage=Dynamic live=1
2017-12-27 12:29:15.636 Info, Node098, Node 98 has been marked as awake
2017-12-27 12:29:15.636 Detail, Node098, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=98): 0x01, 0x0a, 0x00, 0x13, 0x62, 0x03, 0x31, 0x04, 0x01, 0x25, 0x2a, 0xbc
2017-12-27 12:29:15.637 Detail, Node098, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=98): 0x01, 0x0a, 0x00, 0x13, 0x62, 0x03, 0x31, 0x04, 0x03, 0x25, 0x2b, 0xbf
2017-12-27 12:29:15.637 Detail, Node098, Queuing (WakeUp) SensorMultilevelCmd_Get (Node=98): 0x01, 0x0a, 0x00, 0x13, 0x62, 0x03, 0x31, 0x04, 0x05, 0x25, 0x2c, 0xbe
2017-12-27 12:29:15.637 Detail, Node098, Queuing (WakeUp) AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x2d, 0xfc
2017-12-27 12:29:15.638 Detail, Node098, Queuing (WakeUp) AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x2e, 0xf0
2017-12-27 12:29:15.638 Detail, Node098, Queuing (WakeUp) AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x09, 0x01, 0x25, 0x2f, 0xf0
2017-12-27 12:29:15.639 Detail, Node098, Queuing (WakeUp) AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0a, 0x01, 0x25, 0x30, 0xec
2017-12-27 12:29:15.639 Detail, Node098, Queuing (WakeUp) AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0b, 0x01, 0x25, 0x31, 0xec
2017-12-27 12:29:15.640 Detail, Node098, Queuing (WakeUp) AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0d, 0x01, 0x25, 0x32, 0xe9
2017-12-27 12:29:15.640 Detail, Node098, Queuing (WakeUp) BatteryCmd_Get (Node=98): 0x01, 0x09, 0x00, 0x13, 0x62, 0x02, 0x80, 0x02, 0x25, 0x33, 0x11
2017-12-27 12:29:15.640 Detail, Node098, Queuing (Query) Query Stage Complete (Dynamic)
2017-12-27 12:29:15.641 Detail, Node098, Notification: Notification - Node Awake
2017-12-27 12:29:15.879 Info, Node098, Sending (WakeUp) message (Callback ID=0x2a, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=98): 0x01, 0x0a, 0x00, 0x13, 0x62, 0x03, 0x31, 0x04, 0x01, 0x25, 0x2a, 0xbc
2017-12-27 12:29:15.888 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:29:15.889 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:29:15.903 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x2a, 0x00, 0x00, 0x03, 0xc2
2017-12-27 12:29:15.903 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x2a received (expected 0x2a)
2017-12-27 12:29:15.904 Info, Node098, Request RTT 24 Average Request RTT 23
2017-12-27 12:29:20.591 Detail, Node098, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x62, 0x02, 0x84, 0x07, 0x10
2017-12-27 12:29:20.592 Info, Node098, Response RTT 4713 Average Response RTT 3601
2017-12-27 12:29:20.592 Info, Node098, Received Wakeup Notification from node 98
2017-12-27 12:29:25.879 Error, Node098, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-27 12:29:25.879 Detail, Node098, Removing current message
2017-12-27 12:29:25.880 Detail, Node098, Notification: Notification - TimeOut
2017-12-27 12:29:25.889 Info, Node098, Sending (WakeUp) message (Callback ID=0x2b, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=98): 0x01, 0x0a, 0x00, 0x13, 0x62, 0x03, 0x31, 0x04, 0x03, 0x25, 0x2b, 0xbf
2017-12-27 12:29:25.897 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:29:25.897 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:29:25.912 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x2b, 0x00, 0x00, 0x02, 0xc2
2017-12-27 12:29:25.913 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x2b received (expected 0x2b)
2017-12-27 12:29:25.913 Info, Node098, Request RTT 23 Average Request RTT 23
2017-12-27 12:29:35.889 Error, Node098, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-27 12:29:35.889 Detail, Node098, Removing current message
2017-12-27 12:29:35.890 Detail, Node098, Notification: Notification - TimeOut
2017-12-27 12:29:35.899 Info, Node098, Sending (WakeUp) message (Callback ID=0x2c, Expected Reply=0x04) - SensorMultilevelCmd_Get (Node=98): 0x01, 0x0a, 0x00, 0x13, 0x62, 0x03, 0x31, 0x04, 0x05, 0x25, 0x2c, 0xbe
2017-12-27 12:29:35.908 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:29:35.908 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:29:35.923 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x2c, 0x00, 0x00, 0x03, 0xc4
2017-12-27 12:29:35.923 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x2c received (expected 0x2c)
2017-12-27 12:29:35.923 Info, Node098, Request RTT 23 Average Request RTT 23
2017-12-27 12:29:45.900 Error, Node098, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-27 12:29:45.901 Detail, Node098, Removing current message
2017-12-27 12:29:45.901 Detail, Node098, Notification: Notification - TimeOut
2017-12-27 12:29:45.910 Info, Node098, Sending (WakeUp) message (Callback ID=0x2d, Expected Reply=0x04) - AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x07, 0x01, 0x25, 0x2d, 0xfc
2017-12-27 12:29:45.919 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:29:45.919 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:29:45.935 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x2d, 0x00, 0x00, 0x02, 0xc4
2017-12-27 12:29:45.935 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x2d received (expected 0x2d)
2017-12-27 12:29:45.935 Info, Node098, Request RTT 24 Average Request RTT 23
2017-12-27 12:29:45.947 Detail, Node098, Received: 0x01, 0x11, 0x00, 0x04, 0x00, 0x62, 0x0b, 0x71, 0x05, 0x07, 0xff, 0x00, 0xff, 0x07, 0xfe, 0x01, 0x03, 0x00, 0x0b
2017-12-27 12:29:45.947 Info, Node098, Response RTT 36 Average Response RTT 1818
2017-12-27 12:29:45.947 Info, Node098, Received Alarm report: type=7, level=255, sensorSrcID=0, type:Burglar event:254, status=255
2017-12-27 12:29:45.948 Detail, Node098, Refreshed Value: old value=7, new value=7, type=byte
2017-12-27 12:29:45.948 Detail, Node098, Changes to this value are not verified
2017-12-27 12:29:45.948 Detail, Node098, Refreshed Value: old value=255, new value=255, type=byte
2017-12-27 12:29:45.948 Detail, Node098, Refreshed Value: old value=0, new value=0, type=byte
2017-12-27 12:29:45.948 Detail, Node098, Refreshed Value: old value=8, new value=254, type=byte
2017-12-27 12:29:45.948 Detail, Node098, Expected reply and command class was received
2017-12-27 12:29:45.948 Detail, Node098, Message transaction complete
2017-12-27 12:29:45.948 Detail, Node098, Removing current message
2017-12-27 12:29:45.948 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:45.979 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:46.043 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:46.125 Detail, Node098, Notification: ValueChanged
2017-12-27 12:29:46.179 Info, Node098, Sending (WakeUp) message (Callback ID=0x2e, Expected Reply=0x04) - AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x08, 0x01, 0x25, 0x2e, 0xf0
2017-12-27 12:29:46.188 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:29:46.188 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:29:46.204 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x2e, 0x00, 0x00, 0x03, 0xc6
2017-12-27 12:29:46.204 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x2e received (expected 0x2e)
2017-12-27 12:29:46.204 Info, Node098, Request RTT 24 Average Request RTT 23
2017-12-27 12:29:56.181 Error, Node098, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-27 12:29:56.181 Detail, Node098, Removing current message
2017-12-27 12:29:56.181 Detail, Node098, Notification: Notification - TimeOut
2017-12-27 12:29:56.204 Info, Node098, Sending (WakeUp) message (Callback ID=0x2f, Expected Reply=0x04) - AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x09, 0x01, 0x25, 0x2f, 0xf0
2017-12-27 12:29:56.212 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:29:56.212 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:29:56.228 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x2f, 0x00, 0x00, 0x02, 0xc6
2017-12-27 12:29:56.229 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x2f received (expected 0x2f)
2017-12-27 12:29:56.229 Info, Node098, Request RTT 24 Average Request RTT 23
2017-12-27 12:30:06.204 Error, Node098, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-27 12:30:06.205 Detail, Node098, Removing current message
2017-12-27 12:30:06.205 Detail, Node098, Notification: Notification - TimeOut
2017-12-27 12:30:06.217 Info, Node098, Sending (WakeUp) message (Callback ID=0x30, Expected Reply=0x04) - AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0a, 0x01, 0x25, 0x30, 0xec
2017-12-27 12:30:06.225 Detail, Node098, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-12-27 12:30:06.225 Detail, Node098, ZW_SEND_DATA delivered to Z-Wave stack
2017-12-27 12:30:13.984 Detail, Node098, Received: 0x01, 0x07, 0x00, 0x13, 0x30, 0x01, 0x03, 0x09, 0xd0
2017-12-27 12:30:13.985 Detail, Node098, ZW_SEND_DATA Request with callback ID 0x30 received (expected 0x30)
2017-12-27 12:30:13.985 Info, Node098, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-12-27 12:30:13.985 Info, Node098, Node 98 has been marked as asleep
2017-12-27 12:30:13.985 Info, Node098, Node not responding - moving message to Wake-Up queue: AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0a, 0x01, 0x25, 0x30, 0xec
2017-12-27 12:30:13.985 Info, Node098, Node not responding - moving message to Wake-Up queue: AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0b, 0x01, 0x25, 0x31, 0xec
2017-12-27 12:30:13.985 Info, Node098, Node not responding - moving message to Wake-Up queue: AlarmCmd_Get (Node=98): 0x01, 0x0c, 0x00, 0x13, 0x62, 0x05, 0x71, 0x04, 0x00, 0x0d, 0x01, 0x25, 0x32, 0xe9
2017-12-27 12:30:13.985 Info, Node098, Node not responding - moving message to Wake-Up queue: BatteryCmd_Get (Node=98): 0x01, 0x09, 0x00, 0x13, 0x62, 0x02, 0x80, 0x02, 0x25, 0x33, 0x11
2017-12-27 12:30:13.985 Info, Node098, Node not responding - moving QueryStageComplete command to Wake-Up queue
2017-12-27 12:30:13.985 Detail, Node098, Notification: Notification - Node Asleep
