I have discovered that the Zooz ZAC36 Titan Water Valve Actuator has a missing configuration option in the dropdown (the parameter is present, but one of the possible options is not). I’m not sure of the process to post this in github (is this considered front end?) I have all the details, just need who/how to tell.
Would have helped if you mentioned which parameter and value. Could be:
(which has been dormant for over a year, unfortunately)
Otherwise, report a bug. https://github.com/zwave-js/node-zwave-js/issues/new/choose
I tried going to the bug report, but it was asking lots of questions that I didn’t know how to find.
So, the parameter is 97, and the missing value is 0 (zero), the description is “Disable Auto Test Mode”.
Source for the information is ZAC36 Valve Actuator Advanced Settings - Zooz Support Center
Well, you’ll need to create that bug report then, or implement it yourself, because parameter 97 is not included in that fix.
https://zwave-js.github.io/node-zwave-js/#/config-files/contributing-files
You can also set the parameter manually very easily via Z-Wave JS UI, or with HA but it’s more complicated using one of the integration actions.
