Zooz USB Z-Wave Plus S2 Stick ZST10 Functionality
I purchased a Zooz USB Z-Wave Plus S2 Stick ZST10 from Amazon last year. I set it up on my pi using the old ZWave Addon without much issue. I later migrated to Zwave JS. According to my Amazon order, I purchased a 700 series with Z-Wave Plus. However, when i bring up the device I get the following:
Firmware: 2.3
Z-Wave Info
Device ID: 1
Device Status: Alive
Device Ready: Yes
Highest Security: Unknown
Z-Wave Plus: No
I do not know if this is because it is not captured because it is the “hub”, or if there is something else going on. The Zwave network works, although I don’t seem to be getting the functions out of my Kwikset SmartCode 888 that others have obtained.
I do know that during the migration to JS, some of the nodes were depreciated and I had to remove them and add them to capture some of their settings.
My questions are if the device information above is correct or match others. Is the firmware up to date compared with others (zero help at ZooZ). I do not want to start over if nothing is wrong, but I will if I have to.
Thank you.
With Zwame.me stick it looks the same, but zwave+ and S2 security works fine.
Thank you!
Your controller supports Z-Wave Plus. That information is meaningless for controllers, only applies to other nodes, so just ignore it.
Well, it still would be fine, if that info get displayed correctly :stuck_out_tongue:
The information is unavailable for connected controllers. The proper fix will be to not display it at all.
