Zooz ZAC98: Will it Work for My Use Case?
Hey all. So I am trying to understand how the Zooz ZAC98 works. There isnt much info online about how it works. Regardless, Im probably over thinking this, but I was hoping I could get some information for my use case.
I have a house wired with an electronic doorbell chime module. This means that the doorbell system provides a constant low voltage to the doorbell button, and when pressed, the voltage changes, which triggers the electronic chime and plays the bell note in the speakers.
I want to make this a smart bell, and Im wondering if the zooz zac98 will be what I need. If it is, Im wondering how this will work. Im thinking that this module is attached to the two wires that connect to the chime via the NC input. You then attach a zwave or wifi dry contact relay on the other end? Am I missing something? Any help would be greatly appreciated! Thanks!
Their online store has quite a but of information. That is not a Z-Wave device, but an accessory that can be used with one.
Smart how? Get notified when the button is pressed? Use HA to trigger the doorbell?
The support people at opensmarthouse & Zooz (same team) are top notch and may be able to assist.
