This is a blueprint for simplifying the configuration of Scenes if you are using the Zooz Zen21 (and probably other Zooz models).
All credit goes to troy, whose template I took inspiration from - OZW - Aeotec ZWA003 NanoMote Quad - Blueprints Exchange - Home Assistant Community (home-assistant.io)
The Zooz Zen21 has 14 scene options:
- (5x) Press Up Button
- (5x) Press Down Button
- Hold Up Button
- Hold Down Button
- Release Up Button
- Release Down Button
This used to mean that you may need up to 14 automations to trigger an event for each. To simplify things, I made a blueprint that gives you the ability to assign an action to each of the 14 scenes.
I have made 2 blueprints available:
- Zooz Zen Template - This is the bare template that you can use to create your own actions for all 14 scene options. You may also take this and build on top of my work.
- Zen Lighting Control - This is my personal blueprint that I use. I will provide more details below.
I use many Zen21 switches to control overhead smart bulbs. The switches have the relay disabled, and my bulbs are grouped to make it easier to control them. Each switch controls one group of lights, but any single switch can also turn off all of the switches at once.
Includes all templated Scene Options, except some common functions are set to provide standard actions
Press Up 1x to turn a target device on. If the device is already on, raise the brightness by 10%
Press Up 2x to set the target device to 100% brightness
Press Down 1x to turn a target device off. If the device is already off, set the brightness to 10%
Press Down 2x to turn off all lights (note - requires light group)
