I just put a Zooz Zen15 on my sump pump to monitor when it runs. It is reporting watts fine but amps are never showing anything.
Anyone else who has one of these and can confirm amps report fine in ZwaveJS2MQTT? My sump pump only runs for about 15 seconds at a time so I am not sure if that is the issue and I haven’t been able to check the logs/zwjs2mqtt interface at the time the sump pump is on yet.
I was on my way out the door to work so couldn’t do much fiddling before I left but my plan was to put a load on that runs longer than the 15 seconds and see if that shows up, but was wondering if anyone else has one working so I know if it’s my switch or something else.
