Zooz zen31 LED dimmer not turning on
I’ve seen some posts about this dimmer wrt HA. Even a partial fix here:
Partial Fix for Zooz Zen31 LED Dimmer
Has anyone been able to get this one working with HA? I was able to include it just fine (excluded/included a couple of times). I can add a bulb to the UI and adjust color values, temperature and brightness, but the LED itself, never lights up. Yes, the dimmer does work. I’m migrating it over from another solution.
Do I need a different dimmer? If so, which ones work well with HA?
Thanks.
