Zooz ZEN34 - Zwave-JS
For those who want the dimmer controls, I actually ended up copying some of the code from Yet another dimmer/scene switch blueprint
In fact, you could probably use the blueprint above for the Zen34 switch without any issues (you’ll have to toggle the scene mode to switch up/down controls), but I modified the script here anyhow to the following:
blueprint:
  name: Zooz ZEN34 Remote scene control
  description: |
    Use the Zooz ZEN34 remote to trigger Scenes and control devices based on varying scenes.
    This Blueprint is currently configured for the zwaveJS platform.
  domain: automation
  input:
    zwave_device:
      description: "List of available Zooz ZEN34 switch."
      selector:
        device:
          integration: zwave_js
          manufacturer: Zooz
          model: ZEN34
    1x_tap_up:
      name: Tap up 1x
      selector:
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
      default: []
    3x_tap_down:
      name: Tap down 3x
      selector:
      default: []
    4x_tap_up:
      name: Tap up 4x
      selector:
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
      default: []
    hold_up:
      selector:
      default: []
    is_loop_for_hold_up:
      name: Key Up/On held loop?
      description: Asserts whether you want to loop the held action until the button is released which could simulate the impact of a dimmer switch
      default: false
      selector:
        boolean:
    hold_down:
      selector:
      default: []
    is_loop_for_hold_down:
      name: Key Down/On held loop?
      default: false
      selector:
        boolean:
    key_up_released:
      name: Key Up/On released
      description: Action to run, when the up button is released.
      default: []
      selector:
    key_down_released:
      name: Key Down/Off released
      description: Action to run, when the down button is released.
      default: []
      selector:
mode: restart
max_exceeded: silent
variables:
  logger: blueprint.zwave_scene_activation
  device_id: !input zwave_device
  key_up_scene_id: "Scene 001"
  key_down_scene_id: "Scene 002"
  is_loop_for_hold_up: !input "is_loop_for_hold_up"
  is_loop_for_hold_down: !input "is_loop_for_hold_down"
  - platform: event
    event_type: zwave_js_value_notification
  - variables:
      scene_id: "{{trigger.event.data.label}}"
      key_pressed: "{{trigger.event.data.value}}"
  - choose:
      # IF triggered node_id is zwave_nodeid
      - conditions:
          - condition: template
            value_template: "{{ trigger.event.data.device_id == device_id }}"
        sequence:
          - choose:
              # IF 1x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and key_pressed == 'KeyPressed' }}"
                sequence: !input 1x_tap_up
              # IF 1x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and key_pressed == 'KeyPressed' }}"
                sequence: !input 1x_tap_down
              # IF 2x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and key_pressed == 'KeyPressed2x' }}"
                sequence: !input 2x_tap_up
              # IF 2x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and key_pressed == 'KeyPressed2x' }}"
                sequence: !input 2x_tap_down
              # IF 3x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and key_pressed== 'KeyPressed3x' }}"
                sequence: !input 3x_tap_up
              # IF 3x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and key_pressed == 'KeyPressed3x' }}"
                sequence: !input 3x_tap_down
              # IF 4x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and key_pressed== 'KeyPressed4x' }}"
                sequence: !input 4x_tap_up
              # IF 4x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and key_pressed == 'KeyPressed4x' }}"
                sequence: !input 4x_tap_down
              # IF 5x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and key_pressed == 'KeyPressed5x' }}"
                sequence: !input 5x_tap_up
              # IF 5x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and key_pressed == 'KeyPressed5x' }}"
                sequence: !input 5x_tap_down
              - conditions:
                    value_template: '{{ scene_id == key_up_scene_id and key_pressed == "KeyReleased" }}'
                sequence: !input "key_up_released"
              - conditions:
                    value_template: '{{ scene_id == key_down_scene_id and key_pressed == "KeyReleased" }}'
                sequence: !input "key_down_released"
              - conditions:
                    value_template: '{{ scene_id == key_up_scene_id and key_pressed == "KeyHeldDown" }}'
                sequence:
                  # if looping is enabled, loop the action indefinitely
                  # repeat until the automation is restarted ie. when the corresponding release message is received
                  - repeat:
                      sequence: !input "hold_up"
                      until: "{{ not is_loop_for_hold_up }}"
              - conditions:
                    value_template: '{{ scene_id == key_down_scene_id and key_pressed == "KeyHeldDown" }}'
                sequence:
                  - repeat:
                      sequence: !input "hold_down"
                      until: "{{ not is_loop_for_hold_down }}"
            # ELSE: unhandled label/value
            default:
              - service: system_log.write
                  level: debug
                  logger: "{{ logger }}"
                  message: "Activated scene '{{ trigger.event.data.scene_label }}' ({{ trigger.event.data.label }}) with value '{{ trigger.event.data.scene_value_label }}' ({{ trigger.event.data.value }}) for node '{{ zwave_nodeid }}' ({{ trigger.event.data.node_id }})"
    # ELSE: unhandled zwave event
    default: []
You’re right! I designed Yet another dimmer/scene blueprint for compatibility among my ZEN34 and Inovelli switches after I noticed how similar they were
Worked beautifully - thanks for posting this!
works great! thanks for posting austrianalex
I recently picked one of these up and my event data was a little different. Big thanks to the OP for the initial setup.
blueprint:
  description:
    "Use the Zooz ZEN34 remote to trigger Scenes and control devices based on varying scenes.
    This Blueprint is currently configured for the zwaveJS platorm."
  domain: automation
  input:
    zwave_device:
      description: List of available Zooz ZEN34 switch.
      selector:
        device:
          manufacturer: Zooz
          model: ZEN34
          multiple: false
    1x_tap_up:
      name: Tap up 1x
      selector:
        action: {}
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
        action: {}
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
        action: {}
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
        action: {}
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
        action: {}
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
        action: {}
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
        action: {}
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
        action: {}
      default: []
    hold_up:
      selector:
        action: {}
      default: []
    hold_down:
      selector:
        action: {}
      default: []
mode: single
variables:
  device_id: !input "zwave_device"
  - platform: event
  - choose:
      - conditions:
        sequence:
          - choose:
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 0 }}"
                sequence: !input "1x_tap_up"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 0 }}"
                sequence: !input "1x_tap_down"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 3 }}"
                sequence: !input "2x_tap_up"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 3 }}"
                sequence: !input "2x_tap_down"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 4 }}"
                sequence: !input "3x_tap_up"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 4 }}"
                sequence: !input "3x_tap_down"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 5 }}"
                sequence: !input "4x_tap_up"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 5 }}"
                sequence: !input "4x_tap_down"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 6 }}"
                sequence: !input "5x_tap_up"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 6 }}"
                sequence: !input "5x_tap_down"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '001' and trigger.event.data.value == 1 }}"
              - conditions:
                    value_template: "{{ trigger.event.data.property_key == '002' and trigger.event.data.value == 2 }}"
            default:
                  level: debug
                  message:
                    Activated scene '{{ trigger.event.data.scene_label }}' ({{ trigger.event.data.label}}) with value '{{ trigger.event.data.scene_value_label }}' ({{ trigger.event.data.value}}) for node '{{ zwave_nodeid }}' ({{ trigger.event.data.node_id }})
    default: []
Hey Alex - I like this blueprint, thanks. I just picked up a Zen34 and have a simple version running in basic automations, but wow… nice blueprint. Only problem is… How this new firmware is coming in in zwave_JS
key_pressed isn’t a thing. It’s the “value”: 0 which comes in as
0 for one press
2 for hold
3 for double
4 for triple
5 for quadruple
6 for five taps
It’s firmware 1.30, there’s a 1.4 that just came out this month, and zwave.js is all up to date as of posting (May 29, 2022)
Driver Version: 9.3.0
Server Version: 1.17.0
Am I missing something? Obviously, it’s not working.
Thank you for posting
What the events are coming in as…
    "event_type": "zwave_js_value_notification",
    "data": {
        "domain": "zwave_js",
        "node_id": 20,
        "home_id": 3766666895,
        "endpoint": null,
        "device_id": "deadbeef97a15deadbeefdeaddead",
        "command_class": 91,
        "command_class_name": "Central Scene",
        "label": "Scene 001",
        "property": "scene",
        "property_name": "scene",
        "property_key": "001",
        "property_key_name": "001",
        "value": 0,
        "value_raw": 0
    "origin": "LOCAL",
    "time_fired": "2022-05-29T06:45:25.715791+00:00",
    "context": {
        "id": "01810edeadbeef1c2e4e60deadbeef",
        "parent_id": null,
        "user_id": null
I had a similar issue with the scene controller from Zooz (Zen32). I had two of them and one had events coming in with the correct string and one that came in with the value and value_raw as the same integer. I contacted Zooz about it and they basically told me to use value_raw as that will be consistent across all devices. I ended up having to rewrite my scene controller to do just that, so you can maybe use the same logic that @jayvarner is using, BUT a safer way that works across multiple devices with potentially different reporting schemes utilizes both value and value_raw:
blueprint:
  description: |
  domain: automation
  input:
    zwave_device:
      selector:
        device:
          manufacturer: Zooz
          model: ZEN34
    1x_tap_up:
      name: Tap up 1x
      selector:
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
      default: []
    3x_tap_down:
      name: Tap down 3x
      selector:
      default: []
    4x_tap_up:
      name: Tap up 4x
      selector:
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
      default: []
    hold_up:
      selector:
      default: []
      selector:
        boolean:
      default: []
    hold_down:
      selector:
      default: []
      selector:
        boolean:
      default: []
    key_up_released:
      default: []
      selector:
    key_down_released:
      default: []
      selector:
mode: restart
variables:
  - platform: event
condition: "{{ trigger.event.data.device_id == device_id }}"
  - variables:
      value_raw: "{{trigger.event.data.value_raw}}"
  - choose:
      - conditions:
        sequence:
          - choose:
              # IF 1x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and (key_pressed == 'KeyPressed' or value_raw == 0) }}"
              # IF 1x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and (key_pressed == 'KeyPressed' or value_raw == 0) }}"
              # IF 2x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and (key_pressed == 'KeyPressed2x' or value_raw == 3) }}"
              # IF 2x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and (key_pressed == 'KeyPressed2x' or value_raw == 3) }}"
              # IF 3x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and (key_pressed== 'KeyPressed3x' or value_raw == 4) }}"
              # IF 3x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and (key_pressed == 'KeyPressed3x' or value_raw == 4) }}"
              # IF 4x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and (key_pressed== 'KeyPressed4x' or value_raw == 5) }}"
              # IF 4x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and (key_pressed == 'KeyPressed4x' or value_raw == 5) }}"
              # IF 5x tap up
              - conditions:
                    value_template: "{{ scene_id == key_up_scene_id and (key_pressed == 'KeyPressed5x' or value_raw == 6) }}"
              # IF 5x tap down
              - conditions:
                    value_template: "{{ scene_id == key_down_scene_id and (key_pressed == 'KeyPressed5x' or value_raw == 6) }}"
              - conditions:
                    value_template: '{{ scene_id == key_up_scene_id and (key_pressed == "KeyReleased" or value_raw == 1 ) }}'
              - conditions:
                    value_template: '{{ scene_id == key_down_scene_id and (key_pressed == "KeyReleased" or value_raw == 1 ) }}'
              - conditions:
                    value_template: '{{ scene_id == key_up_scene_id and (key_pressed == "KeyHeldDown" or value_raw == 2) }}'
                sequence:
                  - repeat:
                      sequence:
                        !input "hold_up"
              - conditions:
                    value_template: '{{ scene_id == key_down_scene_id and (key_pressed == "KeyHeldDown" or value_raw == 2)}}'
                sequence:
                  - repeat:
                      sequence:
                        !input "hold_down"
            default:
                  level: debug
    default: []
Solid gold, my friend. This seems to work pretty reliably. Thank you!
I was wondering if you can you explain why you commented out the delay in the looping area of the automation?
Regards, and thank you again for helping me make sense of this.
Oh I forgot I did that - it was something I was playing around with. You can set a delay as one of your actions when you are setting up your automation if you need it; no need to hardcode it into the template/blueprint.
This may seem strange, and perhaps it’s a coincidence, but when I uncommented the delays in the bluebring, any automations I created wouldn’t show up in the GUI or operate at all. I had to manually prune them out of automations.yaml and get rid of the delays to make it operate normally again. Odd, and I’m not sure that’s the reason, but its what I experienced right now.
By the way, I also notice that when I turn off the loop function, in the automation, the little ‘switch’ icon will turn back to “on” after several seconds.
On the other hand, it doesn’t actually seem to loop. Any suggestions on how I could troubleshoot this? For example, the path exists in the trace, but never shows it activating.
I updated this script to allow the option for multiple device selection.
Use Case, I have two of these switches in either side of our bed and want them to do the same.
blueprint:
  description: |
  domain: automation
  input:
    zwave_devices:
      selector:
        device:
          manufacturer: Zooz
          model: ZEN34
          multiple: true
    1x_tap_up:
      name: Tap up 1x
      selector:
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
      default: []
    3x_tap_down:
      name: Tap down 3x
      selector:
      default: []
    4x_tap_up:
      name: Tap up 4x
      selector:
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
      default: []
    hold_up:
      selector:
      default: []
      selector:
        boolean:
      default: []
    hold_down:
      selector:
      default: []
      selector:
        boolean:
      default: []
    key_up_released:
      default: []
      selector:
    key_down_released:
      default: []
      selector:
mode: restart
variables:
  device_ids: !input zwave_devices
  - platform: event
condition: "{{ trigger.event.data.device_id in device_ids }}"
  - variables:
  - choose:
      - conditions:
            value_template: "{{ trigger.event.data.device_id in device_ids }}"
        sequence:
          - choose:
              # IF 1x tap up
              - conditions:
              # IF 1x tap down
              - conditions:
              # IF 2x tap up
              - conditions:
              # IF 2x tap down
              - conditions:
              # IF 3x tap up
              - conditions:
              # IF 3x tap down
              - conditions:
              # IF 4x tap up
              - conditions:
              # IF 4x tap down
              - conditions:
              # IF 5x tap up
              - conditions:
              # IF 5x tap down
              - conditions:
              - conditions:
              - conditions:
              - conditions:
                sequence:
                  - repeat:
                      sequence:
                        !input "hold_up"
              - conditions:
                sequence:
                  - repeat:
                      sequence:
                        !input "hold_down"
            default:
                  level: debug
    default: []
Hey folks, reading through this thread, I have everything working except holding the switch up/down. It looks like in the actual Blueprint the call is “KeyHeld” and someone makes the reference to “KeyHeldDown.” I have used the blueprint as it stands and also have edited the Blueprint to use KeyHeldDown and cannot get the device to call the scene either way. Like I said, no problems with tap at all (even with the scene I want to call). Thoughts?
I’m having the same issue.
Same thing is happening to me.
I have this working great! One problem though, on my Zen34 device page it doesn’t show any automations. Anyone know how I can get my automation to show up there?
I’m also having the “hold down” issue. Can anyone fix the blueprint? If not, this might be a deal-breaker for me and I’ll send it back which is a shame. I have another one working (with hold-down) in Smartthings but I’m trying to convert to all HA. If we can’t get this blueprint fixed, can someone point me to how I might be able to configure hold up and hold down outside of the blueprint?
Hey All -
I didn’t end up using hold down here, but instead set a group association between this and a dimmer, so now if I hold it down, it dims the same light as the wired dimmer.
However this was really important - I realized that this automation was running EVERY time that a z-wave device was being triggered (I literally turned on a random light switch for a coat closet and this triggered). I thought it was odd, and it seems the trigger in the code is set to run for exactly that - ANY z wave js notification.
I updated this to the following to target the trigger to this device ONLY:
  - platform: event
    event_data:
Here is another blueprint that has the functionality you might be looking for when you hold down…
Thanks for posting your blueprint @kylerw! It would have taken me days and days to figure all of this out.
Also, thanks to those that posted about the ‘KeyHeldDown’ issue. I was able to update the blueprint with this quick change.
This is such a great community!
I am very new at Blueprint on HA and unfortunately confused about how to import the correct version for Zwave JS. I have 2 of these :
Status: Asleep
Ready: Yes
Highest security: S2 Authenticated
Z-Wave Plus: Version 2
Status: Asleep
Ready: Yes
Highest security: None
The idea is to activate Kitchen Ceiling Switch with Upper paddle for ON and Lower paddle for OFF.
Could someone PLEASE help configure the correct Blueprint so that I just have to do a copy/paste, with as few manual inputs from me as possible ? I am not really interested in multiple clicks on the paddles. Simple ON and OFF are what I need. If there is a simpler solution with Visual Editor, then even better.
