Zooz ZEN34 - Zwave-JS
I have not tested yet as my devices are in the mail, but here is a blueprint for the Zooz ZEN34 remote/switch. I used the ZEN34 documentation from Zooz, here: How to Program Your ZEN34 Remote Switch on Home Assistant - Zooz Support Center
blueprint:
  name: Zooz ZEN34 Remote scene control
  description: |
    Use the Zooz ZEN34 remote to trigger Scenes and control devices based on varying scenes.
    This Blueprint is currently configured for the zwaveJS platform.
  domain: automation
  input:
    zwave_device:
      description: "List of available Zooz ZEN34 switch."
      selector:
        device:
          integration: zwave_js
          manufacturer: Zooz
          model: ZEN34
    1x_tap_up:
      name: Tap up 1x
      selector:
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
      default: []
    3x_tap_down:
      name: Tap down 3x
      selector:
      default: []
    4x_tap_up:
      name: Tap up 4x
      selector:
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
      default: []
    hold_up:
      selector:
      default: []
    hold_down:
      selector:
      default: []
mode: single
variables:
  logger: blueprint.zwave_scene_activation
  device_id: !input zwave_device
  - platform: event
    event_type: zwave_js_value_notification
  - choose:
      # IF triggered node_id is zwave_nodeid
      - conditions:
          - condition: template
            value_template: "{{ trigger.event.data.device_id == device_id }}"
        sequence:
          - choose:
              # IF 1x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 001' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input 1x_tap_up
              # IF 1x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 002' and trigger.event.data.value == 'KeyPressed' }}"
                sequence: !input 1x_tap_down
              # IF 2x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 001' and trigger.event.data.value == 'KeyPressed2x' }}"
                sequence: !input 2x_tap_up
              # IF 2x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 002' and trigger.event.data.value == 'KeyPressed2x' }}"
                sequence: !input 2x_tap_down
              # IF 3x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 001' and trigger.event.data.value == 'KeyPressed3x' }}"
                sequence: !input 3x_tap_up
              # IF 3x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 002' and trigger.event.data.value == 'KeyPressed3x' }}"
                sequence: !input 3x_tap_down
              # IF 4x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 001' and trigger.event.data.value == 'KeyPressed4x' }}"
                sequence: !input 4x_tap_up
              # IF 4x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 002' and trigger.event.data.value == 'KeyPressed4x' }}"
                sequence: !input 4x_tap_down
              # IF 5x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 001' and trigger.event.data.value == 'KeyPressed5x' }}"
                sequence: !input 5x_tap_up
              # IF 5x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 002' and trigger.event.data.value == 'KeyPressed5x' }}"
                sequence: !input 5x_tap_down
              # IF hold up
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 001' and trigger.event.data.value == 'KeyHeld' }}"
                sequence: !input hold_up
              # IF hold down
              - conditions:
                    value_template: "{{ trigger.event.data.label == 'Scene 002' and trigger.event.data.value == 'KeyHeld' }}"
                sequence: !input hold_down
            # ELSE: unhandled label/value
            default:
              - service: system_log.write
                  level: debug
                  logger: "{{ logger }}"
                  message: "Activated scene '{{ trigger.event.data.scene_label }}' ({{ trigger.event.data.label }}) with value '{{ trigger.event.data.scene_value_label }}' ({{ trigger.event.data.value }}) for node '{{ zwave_nodeid }}' ({{ trigger.event.data.node_id }})"
    # ELSE: unhandled zwave event
    default: []
I’m trying to get it to work, so far it’s not working.
Minor fix, the button_id variable should be property_key_name: https://gist.github.com/philk/5b7c39afcd64d354f04b94fb0217abe1
Working great now, thanks for doing most of the work :grin:
Awesome, thanks. Fixed the OP
can’t seem to get it to work – even tried to tap up 7 times to wake it up.
Hey, this is fantastic! Thanks for the hard work. I think you missed the conditions for the long key presses. This should fix it up.
    - conditions: '{{ button_id == "002" and press_count == "KeyHeldDown" }}'
      sequence: !input KeyHeld_Down
    - conditions: '{{ button_id == "001" and press_count == "KeyHeldDown" }}'
      sequence: !input KeyHeld_Up
Great feedback. Modified the OP to include.
Has this blueprint been updated for the change in zwave js?
Yes. it has.
anyone get terrible range on their zen34? I have an aeotec stick plugged into USB2 port on a Pi4 and only get like 20 feet of range…
My Zen34 has okay range, but zwjs/my controller seem to forget it exists about once a week.
I had just converted this for myself before finding this post. OP did not work for me but the below is functioning.
blueprint:
  description: |
  domain: automation
  input:
    zwave_device:
      selector:
         device:
            manufacturer: Zooz
            model: ZEN34
    1x_tap_up:
      name: Tap up 1x
      selector:
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
      default: []
    3x_tap_down:
      name: Tap down 3x
      selector:
      default: []
    4x_tap_up:
      name: Tap up 4x
      selector:
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
      default: []
    hold_up:
      selector:
      default: []
    hold_down:
      selector:
      default: []
mode: single
variables:
  - platform: event
  - choose:
      - conditions:
        sequence:
          - choose:
            # IF 1x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 001 and trigger.event.data.value == KeyPressed }}"
            # IF 1x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 002 and trigger.event.data.value == KeyPressed }}"
            # IF 2x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 001 and trigger.event.data.value ==  KeyPressed2x }}"
            # IF 2x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 002 and trigger.event.data.value ==  KeyPressed2x }}"
            # IF 3x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 001 and trigger.event.data.value == KeyPressed3x }}"
            # IF 3x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 002 and trigger.event.data.value == KeyPressed3x }}"
            # IF 4x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.scene_id == Scene 001 and trigger.event.data.value == KeyPressed4x }}"
            # IF 4x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 002 and trigger.event.data.value == KeyPressed4x }}"
            # IF 5x tap up
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 001 and trigger.event.data.value == KeyPressed5x }}"
            # IF 5x tap down
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 002 and trigger.event.data.value == KeyPressed5x }}"
            # IF hold up
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 001 and trigger.event.data.value == KeyHeld }}"
            # IF hold down
              - conditions:
                    value_template: "{{ trigger.event.data.label == Scene 002 and trigger.event.data.value == KeyHeld }}"
            default:
                  level: debug
    default: []
It looks like the OP blueprint doesn’t work with zwavejs. I’d like to add yours. How do I add it since it’s not hosted on GitHub?
I haven’t had any luck with kylerw or griffioenjake blueprint in HA using Zwave JS. Definitely could be an issue with my setup just posting in case anyone else is having issues thanks for the work and posting for others to use.
[griffioenjake] blueprint creates the automation but it never shows up in the gui under automation. I can see the autiomation is created under the automations.yaml.
[kylerw] blueprint gives an Error: listed below
UndefinedError: ‘dict object’ has no attribute ‘event’
Triggered manually at May 7, 2021, 8:25:41 AM
Define variables button_id, press_count
Stopped because an error was encountered at May 7, 2021, 8:25:41 AM (runtime: 0.00 seconds)
Below is what I setup in automations to get my self up and running for now. Maybe it can help someone get the button working that is having issues.
alias: Zooz Zen34 Button
description: 'Zooz Zen 34 Button automation'
  - platform: event
    event_data:
      node_id: 22
      label: Scene 001
      value: KeyPressed
condition: []
  - type: toggle
    device_id: 8675309
    entity_id: light.desklamp
    domain: light
mode: single
'Above a upper button press action automation to turn on light example'
'node_id: is the node id number can find under device info'
'label: Scene 001 for upper Scene 002 lower paddle'
'value: KeyPressed [KeyPressed = 1 x tap, KeyReleased = released, KeyHeld = held, KeyPressed2x = 2 x tap, KeyPressed3x = 3 x tap, KeyPressed4x = 4 x tap, KeyPressed5x = 5 x tap]'
I’ve tried a few more things to make this blueprint work. I was incorrect earlier. It does seem like the OP had updated his blueprint to use Z-Wave JS. I am, however, experiencing the following as well:
I have no idea what would cause this behavior—automation is created in automation.yaml BUT NOT in the gui. Happy to help troubleshoot more if anyone has any suggestions.
I am not experiencing the following:
With a few tweaks to your code, it finally works for me! I had to escape the string names in the templates and fix one bug in the 4x_tap_up case.
blueprint:
  description: |
  domain: automation
  input:
    zwave_device:
      selector:
        device:
          manufacturer: Zooz
          model: ZEN34
    1x_tap_up:
      name: Tap up 1x
      selector:
      default: []
    1x_tap_down:
      name: Tap down 1x
      selector:
      default: []
    2x_tap_up:
      name: Tap up 2x
      selector:
      default: []
    2x_tap_down:
      name: Tap down 2x
      selector:
      default: []
    3x_tap_up:
      name: Tap up 3x
      selector:
      default: []
    3x_tap_down:
      name: Tap down 3x
      selector:
      default: []
    4x_tap_up:
      name: Tap up 4x
      selector:
      default: []
    4x_tap_down:
      name: Tap down 4x
      selector:
      default: []
    5x_tap_up:
      name: Tap up 5x
      selector:
      default: []
    5x_tap_down:
      name: Tap down 5x
      selector:
      default: []
    hold_up:
      selector:
      default: []
    hold_down:
      selector:
      default: []
mode: single
variables:
  - platform: event
  - choose:
      - conditions:
        sequence:
          - choose:
              # IF 1x tap up
              - conditions:
              # IF 1x tap down
              - conditions:
              # IF 2x tap up
              - conditions:
              # IF 2x tap down
              - conditions:
              # IF 3x tap up
              - conditions:
              # IF 3x tap down
              - conditions:
              # IF 4x tap up
              - conditions:
              # IF 4x tap down
              - conditions:
              # IF 5x tap up
              - conditions:
              # IF 5x tap down
              - conditions:
              # IF hold up
              - conditions:
              # IF hold down
              - conditions:
            default:
                  level: debug
    default: []
Thanks hahahilarious
This worked great for me!
This is brilliant - thanks!!! Any option to have multiple switches rather than just one - I have 3 entrances to my Lodge, and want the same action for each switch for button press, 2x and 3x button press.
I’m using the blue print shared by @hahahilarious on May 17 and I cannot get the hold down and hold up to work to increase and decrease the brightness of my lights. I’m new to this so any suggestions on how to debug this problem would be much appreciated. Thanks!
The hold down and up events are coming in as KeyHeldDown and not KeyHeld. If you update the blueprint in those two locations it’ll work…sort of. It’ll only send one hold down or up event, so you have to release the button and hold it down again to perform the action.
