This is a blueprint to easily configure actions triggered by activating the switch input of the Zooz ZEN51 Dry Contact Relay.
The scene control option must be enabled (Parameter 5: Value:1).
The input can be pressed from 1x to 5x as well as input hold and release.
I am using it with a momentary push button, i’m not sure what the results will be with other types of switches.
blueprint:
name: Zooz Zen51 Scene Control Setup
description: Create an automation for the Zooz Zen51 relay using ZWAVE-JS
integration
domain: automation
input:
zooz_zen51:
description: The Zooz Zen51 to interact with.
selector:
device:
integration: zwave_js
manufacturer: Zooz
model: ZEN51
multiple: false
button_1_1:
name: Press Button 1x
description: Action to run on button press.
default: []
selector:
action: {}
button_1_2:
name: Press Button 2x
description: Action to run on 2 button presses.
default: []
selector:
action: {}
button_1_3:
name: Press Button 3x
description: Action to run on 3 button presses.
default: []
selector:
action: {}
button_1_4:
name: Press Button 4x
description: Action to run on 4 button presses.
default: []
selector:
action: {}
button_1_5:
name: Press Button 5x
description: Action to run on 5 button presses.
default: []
selector:
action: {}
button_1_held:
description: Action to run on button hold.
default: []
selector:
action: {}
button_1_released:
description: Action to run on button release.
default: []
selector:
action: {}
mode: single
max_exceeded: silent
platform: event
event_type: zwave_js_value_notification
event_data:
command_class_name: Central Scene
device_id: !input zooz_zen51
- variables:
scene_id: '{{ trigger.event.data.property_key_name }}'
scene_value_id: '{{ trigger.event.data.value }}'
- choose:
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyPressed'' }}'
sequence: !input button_1_1
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyPressed2x'' }}'
sequence: !input button_1_2
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyPressed3x'' }}'
sequence: !input button_1_3
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyPressed4x'' }}'
sequence: !input button_1_4
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyPressed5x'' }}'
sequence: !input button_1_5
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyHeldDown'' }}'
sequence: !input button_1_held
- conditions: '{{ scene_id == ''001'' and scene_value_id == ''KeyReleased'' }}'
sequence: !input button_1_released
