Zooz ZEN71 - Detect OFF button press when light is already OFF
I’m trying to have a switch by my front door control my main hall lights (in addition to the lights the switch normally controls). I set up direct association so turning the front door switch on or off will also turn the hall lights on or off.
The problem is that when I am in the house, I will just turn the hall lights on and not the light by the front door. I’d like to make it so when I press the OFF button (bottom paddle) on the front door switch, it turns off the hall lights even if the front door lights are already off. So in this case I can’t use a state change as it’s already off.
It looks like if I turn on scene control on the switch, then I can accomplish this with “Central Scene action on Endpoint 0 Scene 002 - KeyPressed”, but I’d like to have scene control off to avoid the delay (as I won’t be using any double-presses on this switch).
So is there a way to detect the bottom paddle being pressed when the lights are already off but without enabling scene control? Thanks.
So upon further investigation, it appears that you must turn on scene control for zwave_js_value_notification to work, which is what I need to accomplish this. I’ll live with the delay.
