Zooz ZEN72
I too ran into an issue with my ZEN72 700 series dimmer on the hold actions. Listening to the event in developer tools I noticed that the raw value (value_raw ) did not match the blueprint on KeyReleased and KeyHeldDown . I corrected the values in the blueprint (KeyReleased from 2 to 1 ; KeyHeldDown from 1 to 2 ), but that broke everything. Instead I removed the or value_raw == <NUMBER> from all the conditions and now everything is working.
Thank you, I had to reverse these as well for it to start working with the dimming on hold
Based on the couple of comments below, any chance you would revise the blueprint? or is it specific to some cases? Thanks!
Thank you. I did make the changes you suggested. Now the hold action only “kind of” works. There is a huge lag. When I keep the button pressed, I see one step increase, but the second step takes forever. And what’s more is that even when I let the button go, it keeps going in the increase/decrease direction. I am setting the delay for the loop to 10 millisecond. So, I would have expected a much faster response.
Set the Automation mode to “Restart” and try it. This made it much better. It still kind of changes in steps which frankly is a bit annoying and slow for me. Not sure I’m going to keep the Zen 72 for a smart light config.
