It worked for me but I had to make a new copy of the yaml file and make the following changes. You can just save it as zooz-zen72-800lr.yaml in the same folder and rename it. I think what is important is the “Model Name” matches.
blueprint:
name: Zooz ZEN72 800LR
description: Automations helper for the Zooz ZEN72 800LR Dimmer Switch using the Zwave
JS integration. Credit and thanks goes to OP and contributors of this thread -
https://community.home-assistant.io/t/zooz-zen72/322433/53
domain: automation
input:
zooz_zen72:
description: The ZEN72 Switch to interact with.
selector:
device:
integration: zwave_js
manufacturer: Zooz
model: ZEN72 800LR
multiple: false
Thanks for the blueprints, it’s been helpful. I’m using this with smart bulbs, so local control is disabled. I was previously using Pico’s but am migrating since these look more like regular light switches and of course I don’t have to bundle all the wires in the switch.
Anyway, the previous blueprint I was using for the pico’s allowed the hold button to continue raising the brightness or dimming of the lights. I’ve tried just inserting the action into the hold - but isn’t not quite right. Was hoping someone might advise what I need to switch.
Previous blueprint for Pico: The section for dim down is near the end…
Hey, I’m not sure if you addressed this (didn’t see it in this thread), but I believe it is (now?) possible to allow multiple models. I noticed the code inside the ZEN32 BP by @fxlt.
I just copied and pasted the updated BP into my BP .yaml. I did noticed that VS Code was throwing some errors at that point, but didn’t make any changes.
I’d originally been importing you BP from a GitHub repo I set up so I could have versioning.
Last night I made the changes manually that made it all stop working. At the end of the night I got the old version working again by reimporting from GH. However that didn’t work for the new version and I’m still getting an error with that.
You’re awesome Ninja! That fixed the errors, and now this is all ready for when the ZAC99s show up that I ordered. Thank you so much for your help and the time spent writing this.
