I have a couple ZEN76, firmware 2.0.1.
The lamp is ON when the switch is OFF in home assistant. Also the LED ON when the load is OFF is also inverted.
2022-09-04T17:41:42.169Z CNTRLR [Node 028] Beginning interview - last completed stage: None
2022-09-04T17:41:42.170Z CNTRLR [Node 028] new node, doing a full interview...
2022-09-04T17:41:42.171Z CNTRLR » [Node 028] querying protocol info...
2022-09-04T17:41:42.182Z DRIVER » [REQ] [GetNodeProtocolInfo]
payload: 0x1c
2022-09-04T17:41:42.191Z DRIVER « [RES] [GetNodeProtocolInfo]
payload: 0xd39c01041001
2022-09-04T17:41:42.197Z CNTRLR « [Node 028] received response for protocol info:
basic device class: Routing Slave
generic device class: Binary Switch
specific device class: Binary Power Switch
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2022-09-04T17:41:42.198Z CNTRLR [Node 028] Interview stage completed: ProtocolInfo
2022-09-04T17:41:42.200Z CNTRLR » [Node 028] querying node info...
2022-09-04T17:41:42.217Z DRIVER » [Node 028] [REQ] [RequestNodeInfo]
payload: 0x1c
2022-09-04T17:41:42.223Z DRIVER « [RES] [RequestNodeInfo]
payload: 0x01
2022-09-04T17:41:42.255Z DRIVER « [Node 028] [REQ] [ApplicationUpdateRequest]
payload: 0x1c130410015e25705b858e595586725a87739f6c7a
2022-09-04T17:41:42.264Z CNTRLR « [Node 028] node info received
supported CCs:
· Z-Wave Plus Info
· Binary Switch
· Configuration
· Central Scene
· Association
· Multi Channel Association
· Association Group Information
· Transport Service
· Version
· Manufacturer Specific
· Device Reset Locally
· Indicator
· Powerlevel
· Security 2
· Supervision
· Firmware Update Meta Data
2022-09-04T17:41:42.267Z CNTRLR [Node 028] Interview stage completed: NodeInfo
2022-09-04T17:41:42.269Z CNTRLR [Node 028] Interviewing Manufacturer Specific...
2022-09-04T17:41:42.270Z CNTRLR » [Node 028] querying manufacturer information...
2022-09-04T17:41:42.281Z DRIVER » [Node 028] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 177
└─[ManufacturerSpecificCCGet]
2022-09-04T17:41:42.288Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.301Z DRIVER « [REQ] [SendData]
callback id: 177
transmit status: OK
2022-09-04T17:41:42.315Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[ManufacturerSpecificCCReport]
manufacturer id: 0x027a
product type: 0x7000
product id: 0xa006
2022-09-04T17:41:42.320Z CNTRLR « [Node 028] received response for manufacturer information:
manufacturer: Zooz (0x027a)
product id: 0xa006
2022-09-04T17:41:42.321Z CNTRLR [Node 028] Interviewing Version...
2022-09-04T17:41:42.323Z CNTRLR » [Node 028] querying the CC version for Version...
2022-09-04T17:41:42.336Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 178
└─[VersionCCCommandClassGet]
CC: Version
2022-09-04T17:41:42.342Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.357Z DRIVER « [REQ] [SendData]
callback id: 178
transmit status: OK
2022-09-04T17:41:42.369Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[VersionCCCommandClassReport]
CC: Version
version: 3
2022-09-04T17:41:42.373Z CNTRLR [Node 028] supports CC Version (0x86) in version 3
2022-09-04T17:41:42.374Z CNTRLR » [Node 028] querying node versions...
2022-09-04T17:41:42.386Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 179
└─[VersionCCGet]
2022-09-04T17:41:42.392Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.407Z DRIVER « [REQ] [SendData]
callback id: 179
transmit status: OK
2022-09-04T17:41:42.420Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[VersionCCReport]
library type: Enhanced Slave
protocol version: 7.13
firmware versions: 2.0
hardware version: 1
2022-09-04T17:41:42.425Z CNTRLR « [Node 028] received response for node versions:
library type: Enhanced Slave (0x03)
hardware version: 1
2022-09-04T17:41:42.426Z CNTRLR » [Node 028] querying CC versions...
2022-09-04T17:41:42.427Z CNTRLR » [Node 028] querying the CC version for Basic...
2022-09-04T17:41:42.438Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 180
CC: Basic
2022-09-04T17:41:42.444Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.459Z DRIVER « [REQ] [SendData]
callback id: 180
transmit status: OK
2022-09-04T17:41:42.469Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Basic
version: 2
2022-09-04T17:41:42.473Z CNTRLR [Node 028] supports CC Basic (0x20) in version 2
2022-09-04T17:41:42.474Z CNTRLR » [Node 028] querying the CC version for Binary Switch...
2022-09-04T17:41:42.485Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 181
CC: Binary Switch
2022-09-04T17:41:42.491Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.505Z DRIVER « [REQ] [SendData]
callback id: 181
transmit status: OK
2022-09-04T17:41:42.516Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Binary Switch
version: 2
2022-09-04T17:41:42.523Z CNTRLR [Node 028] supports CC Binary Switch (0x25) in version 2
2022-09-04T17:41:42.524Z CNTRLR [Node 028] skipping query for All Switch (0x27) because max implemented vers
ion is 0
2022-09-04T17:41:42.524Z CNTRLR » [Node 028] querying the CC version for Z-Wave Plus Info...
2022-09-04T17:41:42.535Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 182
CC: Z-Wave Plus Info
2022-09-04T17:41:42.541Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.556Z DRIVER « [REQ] [SendData]
callback id: 182
transmit status: OK
2022-09-04T17:41:42.567Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
version: 2
2022-09-04T17:41:42.571Z CNTRLR [Node 028] supports CC Z-Wave Plus Info (0x5e) in version 2
2022-09-04T17:41:42.572Z CNTRLR » [Node 028] querying the CC version for Configuration...
2022-09-04T17:41:42.585Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 183
CC: Configuration
2022-09-04T17:41:42.591Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.606Z DRIVER « [REQ] [SendData]
callback id: 183
transmit status: OK
2022-09-04T17:41:42.616Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Configuration
version: 4
2022-09-04T17:41:42.620Z CNTRLR [Node 028] supports CC Configuration (0x70) in version 4
2022-09-04T17:41:42.621Z CNTRLR » [Node 028] querying the CC version for Central Scene...
2022-09-04T17:41:42.633Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 184
CC: Central Scene
2022-09-04T17:41:42.640Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.654Z DRIVER « [REQ] [SendData]
callback id: 184
transmit status: OK
2022-09-04T17:41:42.665Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Central Scene
version: 3
2022-09-04T17:41:42.669Z CNTRLR [Node 028] supports CC Central Scene (0x5b) in version 3
2022-09-04T17:41:42.669Z CNTRLR » [Node 028] querying the CC version for Association...
2022-09-04T17:41:42.679Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 185
CC: Association
2022-09-04T17:41:42.686Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.700Z DRIVER « [REQ] [SendData]
callback id: 185
transmit status: OK
2022-09-04T17:41:42.711Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Association
version: 3
2022-09-04T17:41:42.715Z CNTRLR [Node 028] supports CC Association (0x85) in version 3
2022-09-04T17:41:42.716Z CNTRLR » [Node 028] querying the CC version for Multi Channel Association...
2022-09-04T17:41:42.726Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 186
CC: Multi Channel Association
2022-09-04T17:41:42.732Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.749Z DRIVER « [REQ] [SendData]
callback id: 186
transmit status: OK
2022-09-04T17:41:42.764Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
version: 4
2022-09-04T17:41:42.775Z CNTRLR [Node 028] supports CC Multi Channel Association (0x8e) in version 4
2022-09-04T17:41:42.779Z CNTRLR » [Node 028] querying the CC version for Association Group Information...
2022-09-04T17:41:42.803Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 187
CC: Association Group Information
2022-09-04T17:41:42.825Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.847Z DRIVER « [REQ] [SendData]
callback id: 187
transmit status: OK
2022-09-04T17:41:42.867Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
version: 3
2022-09-04T17:41:42.890Z CNTRLR [Node 028] supports CC Association Group Information (0x59) in version 3
2022-09-04T17:41:42.893Z CNTRLR » [Node 028] querying the CC version for Transport Service...
2022-09-04T17:41:42.919Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 188
CC: Transport Service
2022-09-04T17:41:42.944Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:42.964Z DRIVER « [REQ] [SendData]
callback id: 188
transmit status: OK
2022-09-04T17:41:43.008Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
version: 2
2022-09-04T17:41:43.029Z CNTRLR [Node 028] supports CC Transport Service (0x55) in version 2
2022-09-04T17:41:43.031Z CNTRLR » [Node 028] querying the CC version for Manufacturer Specific...
2022-09-04T17:41:43.064Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 189
CC: Manufacturer Specific
2022-09-04T17:41:43.083Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.104Z DRIVER « [REQ] [SendData]
callback id: 189
transmit status: OK
2022-09-04T17:41:43.136Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
version: 2
2022-09-04T17:41:43.167Z CNTRLR [Node 028] supports CC Manufacturer Specific (0x72) in version 2
2022-09-04T17:41:43.170Z CNTRLR [Node 028] skipping query for Device Reset Locally (0x5a) because max implem
ented version is 1
2022-09-04T17:41:43.173Z CNTRLR » [Node 028] querying the CC version for Indicator...
2022-09-04T17:41:43.213Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 190
CC: Indicator
2022-09-04T17:41:43.242Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.253Z DRIVER « [REQ] [SendData]
callback id: 190
transmit status: OK
2022-09-04T17:41:43.268Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Indicator
version: 3
2022-09-04T17:41:43.279Z CNTRLR [Node 028] supports CC Indicator (0x87) in version 3
2022-09-04T17:41:43.282Z CNTRLR [Node 028] skipping query for Powerlevel (0x73) because max implemented vers
ion is 1
2022-09-04T17:41:43.285Z CNTRLR [Node 028] skipping query for Security 2 (0x9f) because max implemented vers
ion is 1
2022-09-04T17:41:43.288Z CNTRLR » [Node 028] querying the CC version for Supervision...
2022-09-04T17:41:43.311Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 191
CC: Supervision
2022-09-04T17:41:43.320Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.333Z DRIVER « [REQ] [SendData]
callback id: 191
transmit status: OK
2022-09-04T17:41:43.345Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Supervision
version: 1
2022-09-04T17:41:43.354Z CNTRLR [Node 028] supports CC Supervision (0x6c) in version 1
2022-09-04T17:41:43.356Z CNTRLR » [Node 028] querying the CC version for Firmware Update Meta Data...
2022-09-04T17:41:43.371Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 192
CC: Firmware Update Meta Data
2022-09-04T17:41:43.376Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-09-04T17:41:43.379Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
CC: Supervision
version: 1
2022-09-04T17:41:43.478Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 192
2022-09-04T17:41:43.484Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.498Z DRIVER « [REQ] [SendData]
callback id: 192
transmit status: OK
2022-09-04T17:41:43.509Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
version: 5
2022-09-04T17:41:43.513Z CNTRLR [Node 028] supports CC Firmware Update Meta Data (0x7a) in version 5
2022-09-04T17:41:43.514Z CNTRLR » [Node 028] querying if Z-Wave Software Get is supported...
2022-09-04T17:41:43.523Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 193
└─[VersionCCCapabilitiesGet]
2022-09-04T17:41:43.529Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.544Z DRIVER « [REQ] [SendData]
callback id: 193
transmit status: OK
2022-09-04T17:41:43.555Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[VersionCCCapabilitiesReport]
supports Z-Wave Software Get command: true
2022-09-04T17:41:43.559Z CNTRLR « [Node 028] Z-Wave Software Get is supported
2022-09-04T17:41:43.559Z CNTRLR » [Node 028] querying Z-Wave software versions...
2022-09-04T17:41:43.569Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 194
└─[VersionCCZWaveSoftwareGet]
2022-09-04T17:41:43.575Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.589Z DRIVER « [REQ] [SendData]
callback id: 194
transmit status: OK
2022-09-04T17:41:43.610Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[VersionCCZWaveSoftwareReport]
SDK version: 7.13.10
appl. framework API version: 10.13.10
appl. framework build number: 423
host interface version: unused
Z-Wave protocol version: 7.13.10
Z-Wave protocol build number: 423
application version: 2.0.1
application build number: 43707
2022-09-04T17:41:43.615Z CNTRLR « [Node 028] received Z-Wave software versions
2022-09-04T17:41:43.641Z CNTRLR [Node 028] Embedded device config loaded
2022-09-04T17:41:43.646Z CNTRLR [Node 028] Interviewing Z-Wave Plus Info...
2022-09-04T17:41:43.647Z CNTRLR » [Node 028] querying Z-Wave+ information...
2022-09-04T17:41:43.657Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 195
└─[ZWavePlusCCGet]
2022-09-04T17:41:43.663Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.678Z DRIVER « [REQ] [SendData]
callback id: 195
transmit status: OK
2022-09-04T17:41:43.691Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[ZWavePlusCCReport]
version: 2
node type: Node
role type: AlwaysOnSlave
icon (mgmt.): 0x0700
icon (user): 0x0704
2022-09-04T17:41:43.696Z CNTRLR « [Node 028] received response for Z-Wave+ information:
Z-Wave+ version: 2
node type: Node
installer icon: 0x0700
user icon: 0x0704
2022-09-04T17:41:43.698Z CNTRLR [Node 028] Interviewing Indicator...
2022-09-04T17:41:43.699Z CNTRLR » [Node 028] scanning supported indicator IDs...
2022-09-04T17:41:43.709Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 196
└─[IndicatorCCSupportedGet]
indicator: 0 (default)
2022-09-04T17:41:43.718Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.730Z DRIVER « [REQ] [SendData]
callback id: 196
transmit status: OK
2022-09-04T17:41:43.743Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[IndicatorCCSupportedReport]
indicator: 0x50 (Node Identify)
supported properties: On/Off Period: Duration, On/Off Cycle Count, On/Off
Period: On time
next indicator: 0 (default)
2022-09-04T17:41:43.749Z CNTRLR « [Node 028] supported indicator IDs: 80
2022-09-04T17:41:43.750Z CNTRLR » [Node 028] requesting current indicator value (id = 0x50)...
2022-09-04T17:41:43.763Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 197
└─[IndicatorCCGet]
2022-09-04T17:41:43.769Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.788Z DRIVER « [REQ] [SendData]
callback id: 197
transmit status: OK
2022-09-04T17:41:43.805Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[IndicatorCCReport]
values:
· indicatorId: 80
propertyId: 3
value: 0
· indicatorId: 80
propertyId: 4
value: 0
· indicatorId: 80
propertyId: 5
value: 0
2022-09-04T17:41:43.811Z CNTRLR [Node 028] Interviewing Firmware Update Meta Data...
2022-09-04T17:41:43.812Z CNTRLR » [Node 028] Querying firmware update capabilities...
2022-09-04T17:41:43.821Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 198
└─[FirmwareUpdateMetaDataCCMetaDataGet]
2022-09-04T17:41:43.827Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.841Z DRIVER « [REQ] [SendData]
callback id: 198
transmit status: OK
2022-09-04T17:41:43.856Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[FirmwareUpdateMetaDataCCMetaDataReport]
manufacturer id: 634
firmware id: 40966
checksum: 0
firmware upgradable: true
max fragment size: 40
additional firmware IDs: []
hardware version: 1
continues to function: unknown
supports activation: unknown
2022-09-04T17:41:43.861Z CNTRLR « [Node 028] Received firmware update capabilities:
firmware targets: 0
2022-09-04T17:41:43.862Z CNTRLR [Node 028] Interviewing Association...
2022-09-04T17:41:43.863Z CNTRLR » [Node 028] querying number of association groups...
2022-09-04T17:41:43.873Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 199
└─[AssociationCCSupportedGroupingsGet]
2022-09-04T17:41:43.879Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.893Z DRIVER « [REQ] [SendData]
callback id: 199
transmit status: OK
2022-09-04T17:41:43.904Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[AssociationCCSupportedGroupingsReport]
group count: 3
2022-09-04T17:41:43.908Z CNTRLR « [Node 028] supports 3 association groups
2022-09-04T17:41:43.909Z CNTRLR » [Node 028] querying association group #1...
2022-09-04T17:41:43.920Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 200
└─[AssociationCCGet]
group id: 1
2022-09-04T17:41:43.926Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.941Z DRIVER « [REQ] [SendData]
callback id: 200
transmit status: OK
2022-09-04T17:41:43.954Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[AssociationCCReport]
group id: 1
max # of nodes: 1
node IDs: 1
reports to follow: 0
2022-09-04T17:41:43.958Z CNTRLR « [Node 028] received information for association group #1:
maximum # of nodes: 1
currently assigned nodes: 1
2022-09-04T17:41:43.959Z CNTRLR » [Node 028] querying association group #2...
2022-09-04T17:41:43.970Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 201
group id: 2
2022-09-04T17:41:43.976Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:43.991Z DRIVER « [REQ] [SendData]
callback id: 201
transmit status: OK
2022-09-04T17:41:44.002Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
group id: 2
max # of nodes: 5
node IDs:
2022-09-04T17:41:44.007Z CNTRLR « [Node 028] received information for association group #2:
maximum # of nodes: 5
2022-09-04T17:41:44.007Z CNTRLR » [Node 028] querying association group #3...
2022-09-04T17:41:44.018Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 202
group id: 3
2022-09-04T17:41:44.024Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.039Z DRIVER « [REQ] [SendData]
callback id: 202
transmit status: OK
2022-09-04T17:41:44.052Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
group id: 3
max # of nodes: 5
node IDs:
2022-09-04T17:41:44.056Z CNTRLR « [Node 028] received information for association group #3:
2022-09-04T17:41:44.057Z CNTRLR [Node 028] AssociationCC: delaying configuration of lifeline associations unti
l after Multi Channel Association interview...
2022-09-04T17:41:44.059Z CNTRLR [Node 028] Interviewing Multi Channel Association...
2022-09-04T17:41:44.060Z CNTRLR » [Node 028] querying number of multi channel association groups...
2022-09-04T17:41:44.069Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 203
└─[MultiChannelAssociationCCSupportedGroupingsGet]
2022-09-04T17:41:44.075Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.090Z DRIVER « [REQ] [SendData]
callback id: 203
transmit status: OK
2022-09-04T17:41:44.100Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[MultiChannelAssociationCCSupportedGroupingsReport]
group count: 3
2022-09-04T17:41:44.104Z CNTRLR « [Node 028] supports 3 multi channel association groups
2022-09-04T17:41:44.105Z CNTRLR » [Node 028] querying multi channel association group #1...
2022-09-04T17:41:44.116Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 204
└─[MultiChannelAssociationCCGet]
group id: 1
2022-09-04T17:41:44.122Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.136Z DRIVER « [REQ] [SendData]
callback id: 204
transmit status: OK
2022-09-04T17:41:44.150Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[MultiChannelAssociationCCReport]
group id: 1
node ids: 1
endpoints:
2022-09-04T17:41:44.155Z CNTRLR « [Node 028] received information for multi channel association group #1:
currently assigned endpoints:
2022-09-04T17:41:44.156Z CNTRLR » [Node 028] querying multi channel association group #2...
2022-09-04T17:41:44.167Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 205
group id: 2
2022-09-04T17:41:44.173Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.188Z DRIVER « [REQ] [SendData]
callback id: 205
transmit status: OK
2022-09-04T17:41:44.199Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
group id: 2
node ids:
endpoints:
2022-09-04T17:41:44.204Z CNTRLR « [Node 028] received information for multi channel association group #2:
2022-09-04T17:41:44.205Z CNTRLR » [Node 028] querying multi channel association group #3...
2022-09-04T17:41:44.216Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 206
group id: 3
2022-09-04T17:41:44.222Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.237Z DRIVER « [REQ] [SendData]
callback id: 206
transmit status: OK
2022-09-04T17:41:44.248Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
group id: 3
node ids:
endpoints:
2022-09-04T17:41:44.253Z CNTRLR « [Node 028] received information for multi channel association group #3:
2022-09-04T17:41:44.254Z CNTRLR [Node 028] Checking/assigning lifeline groups: 1
supports classic associations: true
supports multi channel associations: true
2022-09-04T17:41:44.255Z CNTRLR [Node 028] Configuring lifeline group #1:
group supports multi channel: true
configured strategy: auto
must use node association: true
must use endpoint association: false
2022-09-04T17:41:44.258Z CNTRLR [Node 028] Lifeline group #1 is already assigned with a node association
2022-09-04T17:41:44.260Z CNTRLR [Node 028] Interviewing Association Group Information...
2022-09-04T17:41:44.261Z CNTRLR » [Node 028] Association group #1: Querying name...
2022-09-04T17:41:44.272Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 207
└─[AssociationGroupInfoCCNameGet]
group id: 1
2022-09-04T17:41:44.283Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.293Z DRIVER « [REQ] [SendData]
callback id: 207
transmit status: OK
2022-09-04T17:41:44.308Z DRIVER « [Node 028] [REQ] [ApplicationCommand]
└─[AssociationGroupInfoCCNameReport]
group id: 1
2022-09-04T17:41:44.312Z CNTRLR « [Node 028] Association group #1 has name "Lifeline"
2022-09-04T17:41:44.313Z CNTRLR » [Node 028] Association group #1: Querying command list...
2022-09-04T17:41:44.324Z DRIVER » [Node 028] [REQ] [SendData]
│ callback id: 208
└─[AssociationGroupInfoCCCommandListGet]
group id: 1
allow cache: true
2022-09-04T17:41:44.330Z DRIVER « [RES] [SendData]
was sent: true
2022-09-04T17:41:44.344Z DRIVER « [REQ] [SendData]
callback id: 208
transmit status: OK
